-   -   Transfer switch for generator (http://www.diychatroom.com/f18/transfer-switch-generator-162890/)
Dave12vette 11-10-2012 08:35 PM
1 Attachment(s)
I have a Reliance ProTran model 31406 transfer switch that I wish to wire into my electrical scheme to run my Generac 5500 watt portable generator. The installation instructions and dvd show basic setup with the 240 volt circuit for the water heater in the electrical panel (just one panel). My electrical service has 2 meters and one large panel for all circuits BUT the water heater, and one small panel just for the water heater. Both panels are fed from outside, the small one is not attached to the large panel in any way.
Does anyone know how I can operate 4 120 volt circuits from the big panel and the 240 volt from the small panel with this transfer switch powered by the generator? I have to bring all the wired into the large panel (most likely), but how do I wire this up?
I will try to attach a pic of the 2 panels.
Regination 11-10-2012 08:57 PM
You have a separate meter for your water heater, I assume because you pay a different rate to power it.
I am not sure how you could do this...
You can get a smaller 2 circuit transfer panel for the water heater, but I am not sure how you could connect both of the transfer panels to one generator. You would be connecting two separate services together which may be illegal.
Do you have a disconnect outside before the meters?
Dave12vette 11-10-2012 09:06 PM
i don't think i have a disconnect outside before the meters
brric 11-10-2012 09:08 PM
Assuming your WH is 4500 watts there is no way I would consider using a 5500 watt generator to power it along with other appliances.
Auger01 11-10-2012 09:11 PM
Piece of cake. Run the wires for the water heater from the switch to the small panel. You will need an extra piece of conduit for that part. Hook the supplied conduit up to the main panel and then just follow the instructions.
Dave12vette 11-10-2012 09:12 PM
thanks for the thoughts on the generator size. the Generac was given to me by a relative. i questioned its ability. it has surge to 6250 watts, so I would need to power everything else down while the water was being heated. would a 7500 watt be sufficient, considering we would only heat the water once a day in a power outage?
Regination 11-10-2012 09:13 PM
So if you got something like this: http://www.platt.com/platt-electric-...px?zpid=572659
You could hook it up to just the water heater service. Then you could switch the generator cord from the main panel transfer switch to the water heater transfer switch when you want to heat the water up.
Dave12vette 11-10-2012 09:15 PM
Auger, Are you saying that I bring all of the transfer switch wires into the main panel THEN (using new conduit) flow the 240 volt wires into the small panel? Hook up all the other 4 circuits into the large panel and ground in that panel too?
Missouri Bound 11-10-2012 09:18 PM
If you only are planning on heating it once a day, this is probably the best way to go.:thumbsup:
Auger01 11-10-2012 09:28 PM
You could do it that way or just use a second piece of conduit direct from switch to the small panel. Both ways would work, it is just a matter of which is easier.
Dave12vette 11-10-2012 09:28 PM
Missouri, Sounds like a very good option.
Dave12vette 11-10-2012 09:29 PM
Auger, Much appreciated
brric 11-10-2012 09:38 PM
You will need two transfer devices unles the transfer is installed ahead of the two meters. If you apply power to the WH from transfer panel without interruption you will backfeed the WH meter and subsequently the main panel meter.
Dave12vette 11-10-2012 10:57 PM
Brric, One of my friends who is an electrician as well agreed with you. 2 devices is perhaps the cleanest way to go. Thanks for your advice.
...and thank you all for your assistance.
brric 11-11-2012 09:08 AM
You're welcome.
