Transfer Switch Configuration - Electrical - DIY Chatroom Home Improvement Forum
Old 08-03-2011, 11:51 PM   #1
jburd964's Avatar
Rewards Points: 166
I have a 15 kw generator and a automatic transfer switch that came with a automatic stand by generator that crapped out on me. My question is how can I use the automatic transfer switch with 10 r 12 20amp breakers to feed my 200 amp main breaker panel as one live feed instead of 10 r 12 seperate 20 amp feeds? Rather not forking out another $600 for a manual transfer switch.
jburd964 is offline   Reply With Quote
Old 08-04-2011, 07:11 AM   #2
Rewards Points: 1,452
What crapped out? The generator or the transfer switch?
Does the existing tranfer switch unit have one large handle or 8 to 10 small handles?
Old 08-04-2011, 07:54 AM   #3
jburd964's Avatar
Rewards Points: 166
Many individual
Old 08-04-2011, 01:43 PM   #4
The transfer switch unit with 8 to 10 small handles is actually a combination of 8 to 10 small transfer switches and one subpanel all in one unit. It can back feed the main panel as a whole only via one (120 volts) or two (for 240 volts) of the small switches each of which is limited to perhaps 20 amps, possibly 30 amps.
This transfer switch unit is meant to handle 8 to 10 selected circuits in your main panel and the panel bus bars and the rest of the branch circuits remain dead during the power outage.
generator transfer switch chuck172 Electrical 8 06-30-2011 04:34 PM
Transfer switch with a 100A subpanel operagost Electrical 7 03-02-2011 10:28 AM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
Transfer switch to main panel connection i6pwr Electrical 3 01-28-2009 07:09 AM
Transfer switch choice i6pwr Electrical 11 01-25-2009 01:35 PM
