Transfer Switch Between Two Electric Meters? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-16-2012, 12:55 PM   #16
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Originally Posted by flasherz View Post
He wants to use a single meter now, but preserve the ability to revert back to two separate meter bases if he rents separately. A simple manual transfer switch as demonstrated above would do this, and likely best done as a subpanel as mentioned.
And would require a change in bonding now and later.
The Following User Says Thank You to k_buz For This Useful Post:
Oso954 (10-16-2012)
Old 10-16-2012, 11:49 PM   #17
Rewards Points: 184
Something similar happened to my house right before we bought it... Was previously 2 family dwelling when owner (at the time) didn't want to keep paying for 2 sewage accounts while it was vacant. She called up and changed it to 1 account and thought everything fine. When I called up to verify zoning status, I was informed it was changed to single family dwelling because of previous owner changing sewage to 1 account and since it did not meet current parking space requirements, it would be denied a 2 dwelling zoning classification again.
Originally Posted by AllanJ View Post
(copied from another forum)
I would recommend not getting rid of the second meter and the second service.
The building is more valuable as a two family compared with being a single family. If you combine the electric services and also do things to make it look like single family usage, the building could be reclassified as single family. The zoning for the neighborhood could change to single family, too, if yours is the last two or more family building. It would take and act of God. or at least an act of Congress, or at least a big hassle with the local planning board, to rezone as multifamily again.
stevekem is offline   Reply With Quote
Generac Transfer Switch Wiring diesel_farmer Electrical 1 12-13-2011 07:31 PM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-08-2011 11:00 PM
Generator output and Transfer Switch aquasport17 Electrical 3 07-12-2011 10:17 AM
generator transfer switch chuck172 Electrical 8 06-30-2011 03:34 PM
Furnace Transfer Switch... caseywa HVAC 16 02-18-2008 09:14 AM
