#1 |
Transfer switch with a 100A subpanel
I have 200A service to my basement with a 100A subpanel on the first floor at the opposite end of the house. I need to install a transfer switch that services both the circuits in the subpanel AND two circuits in the main panel. The transfer switches I have seen don't seem to support a 100A circuit. I need to support both because most of the living space is in the subpanel while vital devices like the boiler, sump pump, water pump, and a freezer are on the main panel.
#2 |
Sounds like you need a whole house 200 amp transfer switch. I don't know of another way to service circuits in two separte panels.
Do not PM with questions that can be asked in a forum. I will not respond. |
#3 |
So I'm looking at a $600 switch. Great!
#4 |
Electrical Contractor
Can you move those circuits to your sub panel? If not, you can move those to another sub panel and just parallel 2-100 amp switches.
If your going with a Generac generator, I have 20 of them I'd let go for $75 ea |
#5 |
I can't move the circuits from the subpanel unless I'm willing to invest in a lot of copper because they're on the opposite side of the house. I was pondering your suggestion of adding a new subpanel though-- near the main load center, I presume. Since the original subpanel is 100A, must the new one be greater than 100A? Remember, in addition to all the stuff in the subpanel, I have to move circuits for boiler, sump pump, and water pump from the main.
Thanks! |
#6 |
Scared Electrician
the size of one panel never reflects on the required size of another panel. Only the load and calcs demand a certain size
Ragged Trousered Philanthropist Please follow the code - its there for your safety no matter how inconvenient. |
#7 |
OK, then my plan should be based on doing a load calc on my existing subpanel circuits, plus the vital circuits in the main panel, to compare the feasibility (including safety concerns) of using a second subpanel next to a full transfer switch.
#8 |
OK: duh, if I move those circuits to a subpanel that means I can get a cheaper 100A transfer switch. I get it! Well, at least I think about these things before sticking my hands in live circuits!
| Display Modes | |
| Grounding requirement for 100A subpanel | blakeasaurus | Electrical | 2 | 12-08-2010 06:59 PM |
| 3-way light with a twist | Jeepsail | Electrical | 14 | 05-18-2010 02:24 AM |
| Transfer switch to main panel connection | i6pwr | Electrical | 3 | 01-28-2009 07:09 AM |
| Transfer switch choice | i6pwr | Electrical | 11 | 01-25-2009 01:35 PM |
| Replacing a bathroom fan switch | cmacjr22 | Electrical | 4 | 11-04-2008 07:14 PM |
