TRANE Furnace - Electrical - DIY Chatroom Home Improvement Forum
Old 07-27-2011, 12:50 PM   #1
TRANE furnace
today when I went to put a new 20X20 filter, the filter was soaked and brought more water out as I removed it. Do I have a problem or will the new filter solve it?
gwenejackson is offline   Reply With Quote
Old 07-27-2011, 01:08 PM   #2
fabrk8r's Avatar
It sounds like your condensate drain is plugged and the drain pan is overflowing.
You can try sucking the condensate drain tube out with a wet-vac. If that doesn't work you can try blowing compressed air into the drain to dislodge and muck and then suck it out. If your condensate line was installed properly there will be a removable cap near the P-trap to aid in cleaning.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 07-27-2011, 04:04 PM   #3
wareagle's Avatar
The pan is usually in the attic. After you get the pan dry, pour Clorox down the drain tubing. If you do that once or twice a year you will not have this happen again.
wareagle is offline   Reply With Quote
filter , leak , trane
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Honeywell stat wiring w/ Trane furnace JaePee HVAC 7 01-18-2009 06:50 AM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
