Trailer Trash Main Power Problems
I consider myself a professional. I do not have the plaque on the wall, so I figured I should join this site instead of the other one for "professionals". Sorry for the sarcasm.
Ok, here's the deal. I have this trailer that has totally lost power. I pulled the plug on it, 30 amp main at the plug with a 20 amp normal recepticle next to it. So the plug is reading that it's getting 110. What it's suppose to get. So that is fine. This is where it gets weird. Now there is a main breaker box inside the trailer with the main wire going to it's own separate 30 amp breaker. So like I said, I pulled the plug, pulled it though the house, got it up to the box to make sure that each wire was fine. No breaks. Hooked up an Ohm meter to each wire fine. All wires are good. Plug it back in with only the main power breaker. The wire has juice, the bar for the other breakers has juice. As soon as I put in another breaker and turn it on... no juice on the bar, and no juice in the breaker. Here is my question. The owner of so called park says he tested the line (like I did) and is getting 110. In my head, I'm like, I can get 110 off of 2amps. So what. Is it possible with no fuses tripping, that the thing outside is pushing a few amps to the trailer and then as soon as I hook up another breaker it's too much for it so nothing runs, yet no fuses are tripping? Just a totally worn out breaker that's been outside for like the last 15 years. Still clicks fine on and off, yet is just gone? Thanks for any help on this in advance. M |
Is this a camping trailer? A mobil home would have 220 volt coming to the panel, not 110.
And would be a min. of 60 amps. not 30. Got some pictures of these panels? |
I can tell by your post that you are a true professional. A professional WHAT, I have no idea.
Mark |
I'm gonna say you have a bad underground.
A... or 1 who are into numbers. Yes it is a mobile. I know that most are 220. This is not. 110 out the door. And it is truly 110 at 30amps. Am going out there to today to test my theory. Will also try to post some pics.
B or 2. Usually the professional jerk to most, until you get to know me. C to a danpik. I understand all of that. What I am asking, is if it is possible for a breaker to be so bad, that it will only allow a few amps to go through it and still not trip. You have to see this thing. Been out in this nasty Humboldt weather for 15 years. K buz..... Hmmm, if this test doesn't go right, you might have a good point there. BUT THEN, the ground is going to the outlet,, argh still might be right at the plug in box. The ground at the box that it plugs into... gotta check that. |
Thing is, once it's at the box outside... it's out of our jurisdiction and I have to rely on the idiots around there that do not know what the heck they are doing to fix it. Hundreds of dollars to get a guy out there to check it, then he doesn't have the part, a couple more hundred to get him to come back with the right part, and this chick is freezing in the mean time. Can't wait for that uh bullpoop.
Comes down to it. I'm just going to bypass them, do it, and they will never know the wiser that I did them a favor for 50 bucks. Just too scary of that main power coming in. Can't get the power company to shut it off. So if I don't reply after this one... you know what happened lol. |
Is this a trailer park?
rrolleston... yes.
So, you are on a diy site, asking how to repair something so you can make money from someone else?
If you are not comfortable doing this then you should leave it alone and let them find someone else to fix it.
jbfan What? I'm talking I'm out 50 bucks for the parts. The chick is freezing and she is my friend. No, not in that way. Get your mind out of the fuze box.
Well, if my test goes wrong on the so called "50 bucks I'm spending to make money thing". I'll have to. Let me get out there, do my test, BUY the parts jbfan, take some photos, and I'll keep you guys up to date. |
| All times are GMT -4. The time now is 05:35 PM. |
