Trailer House Electric Issue - Electrical - DIY Chatroom Home Improvement Forum
Old 11-09-2013, 07:40 PM   #1
trailer house electric issue
I have a electrical issue in a trailer house, it is tied to my Stove, Dishwasher and 2 outlets and porch light. the 2 outlets and porch light are on the same line and on the left side of the CB box while the Stove and DW is on the right, separate cbs. I have a intermittent power issue. I found out today that if turn on the dw is did not work and the stove clock was out. I turned on one burner and clock came on and the DW started working. I check the CB connections they are tight, any ideas
chuckcnm is offline   Reply With Quote
Old 11-09-2013, 08:01 PM   #2
Rewards Points: 12,790
Call the power company ASAP, not tomorrow.
Sounds like a dropped neutral which can destroy anything that's plugged in at the time.
Old 11-09-2013, 08:16 PM   #3
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
my first thought was lost LEG ... >>>>turing on stove ( 240 )
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
The Following 2 Users Say Thank You to Philly Master For This Useful Post:
Glennsparky (11-09-2013), k_buz (11-10-2013)
Old 11-09-2013, 08:45 PM   #4
Electrician
Rewards Points: 150
A lost leg means no power on one of the two incoming hot (black) wires. This can happen on the utility side, transformer or sometimes meter. That's the power company's responsibility.
Or it can happen on your side. The outside main disconnect or in the CB box. Maybe a loose main feed connection or maybe the main breaker went bad. That's not the power company's responsibility. You may need to hire an electrician.
Glennsparky is offline   Reply With Quote
Old 11-09-2013, 09:45 PM   #5
I would of thought it would have been the house cause:
Left side of CB panel is the 2 out lets and porch light
Right side of the CB panel is the stove and dishwasher.
Right now that all appears to be not working, the trailer is empty right now so I tell if anything else I wrong yet
Old 11-10-2013, 12:57 AM   #6
Licensed electrician
Rewards Points: 996
I too am in the lost a hot leg camp.
Philly Master (11-10-2013)
Old 11-10-2013, 01:45 AM   #7
dmxtothemax's Avatar
Rewards Points: 5,096
If the loads don't work on there own, but do work to some extent when both are on, this indicates a lost neutral causing backfeeding. To test you need a volt metet. Test from each hot to neutral. One will be ok the other not. Also test between both hots should be 240v.
Be carefull when testing.
dmxtothemax is offline   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
Old 11-10-2013, 02:29 AM   #8
Rewards Points: 6,652
The problem with most trailers, is that they use sometimes XLP cable from the Meter pedestal to the trailer.
There are some areas that the power company will not touch anything in the mobile home park, and will require that you contact an electrician, or the park have an electrician perform any work inside the perimeter of the park, since most POCo's consider the border of the proper outside as their equipment, anything inside the border of the property, the responsibility of whoever those that live there pay rent or lease money to.
Most likely what has happened with the OP, is either someone was digging, and cut a leg somewhere, along the pah of the common feeder between meter pedestals, so it is best for them to go and ask their neighbors, if they are also having any issues inside their mobile home.
The worse thing is, there is a lot of older mobile homes that were built with Aluminum wiring in them, and people are still living in them. Then you have the ones that use the 1960's style cloth covered Romex.
Really without knowing the age of the mobile home, what kind of panel is in the place, what kind of wire connects them from the structure to the meter pedestal, are others downstream or upstream of their domicile also having power issues, everyone is really just taking a guess here, what the real issue may be.
For all we know, it could be just a bad breaker at either the Meter pedestal, or a bad main breaker inside the mobile home. Worse case is that someone was out digging along the path of the common feeder between meter pedestals, and sliced one of the legs.
Old 11-10-2013, 09:57 AM   #9
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
I'm thinking lost or loose neutral.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 11-10-2013, 10:04 AM   #10
Rewards Points: 516
how does that work ...
i have seen NO nuetral but house is fine cause of the water pipe connection ...
i do not get the back feed and neutral working ....
i get one leg no good .L1.. and turning on a 240 back feeding the panel so the other side L2 now feeds the L1 ....
Old 11-10-2013, 06:34 PM   #11
According to the O / P the dishwasher and stove are on opposite legs,
Dishwasher no go,
Turn stove on and dishwasher shows some signs of life
IE - The dishwasher clock comes on !
Sounds like classic back feeding to me ?
So most likely a lost neutral,
But needs some testing to confirm the theory !
Old 11-10-2013, 06:38 PM   #12
An old Tradesmen
Rewards Points: 6,060
Dishwasher no go,
The stove is most likely 240 volt. So when he turns on the stove, its back feeding the other leg. Probably only has 1 leg hot from the meter, or panel.
Old 11-10-2013, 06:47 PM   #13
Sorry didnt realise that the stove was 240v !
If it is, then yes your theory sounds right.
Now all we have to do is test to prove it !
Sounds like there is a loose connection on one leg.
Has there been any tests yet ?
Old 11-10-2013, 10:11 PM   #14
wow thanks for all the help, I have the power company coming out tomorrow I hope. This is not a trailer park, it is on some land I own. I did also notice that the water pump was acting a little funny kind of weak water pressure at time. I have a pole light that has kind of a dull clicking noise coming from it if that helps. I will post what the POCO says tomorrow.
Old 11-11-2013, 06:41 AM   #15
Your going to end up burning up that pump and anything else that plugged in if that powers left on.
changing location of electric service to the detached garage from the house. marlowc2 Electrical 3 06-13-2011 12:30 AM
Need Help - House Electrical Issue nottimtaylor Electrical 2 10-19-2010 09:10 AM
running electric from house Tradesman14 Electrical 3 01-14-2010 12:16 PM
House electrical wiring issue. gnidaerd General DIY Discussions 5 06-07-2009 03:42 AM
Remodeling a 14x72 trailer house - HELP! Kris G Carpentry 4 05-20-2009 09:52 AM
