Track Lighting Turns On And No Longer Has Dimmer Control - Electrical - DIY Chatroom Home Improvement Forum
Old 06-03-2009, 08:38 AM   #1
Unhappy
track lighting turns on and no longer has dimmer control
the track lighting that has been up there for at least 3 years now still turns on and off but lost its dimmer control functionality. The switch is a simple lever switch, not a touch switch. Could it of been a spike that may have got it, or transformer for the track light. ??
nyfilm123 is offline   Reply With Quote
Old 06-03-2009, 09:54 AM   #2
Rewards Points: 502
Is this a lever switch that depending on the position of the lever switch determines the intensity of the lights?
If so, sounds like you need to replace the dimmer switch.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 06-03-2009, 12:00 PM   #3
Rewards Points: 78
Not sure what cause it to fail, but it did. Just get a new one.
J. V. is online now   Reply With Quote
Old 06-03-2009, 10:36 PM   #4
yes it was the dimmer switch... thanks
Old 06-03-2009, 10:46 PM   #5
Say it Is not so!!!!
Fried Rheostat!!!!
Buy a Heavier Duty one and provide Ventilation!
MALCO.New.York is offline   Reply With Quote
Old 06-05-2009, 12:03 AM   #6
Union Electrician
goose134's Avatar
You mentioned a transformer in the track light. It may be that the dimmer is not the correct kind. If you have electronic transformers in each track head ( like the MR-16 kinds so popular today), then you will need an electronic low voltage dimmer. If it is a large transformer that powers a low voltage bus type track, then you will need a magnetic low-voltage dimmer.
The wrong kind will work for a time, but will eventually fail.
goose134 is offline   Reply With Quote
Tags
track lighting
LED track lighting feasible yet? GFW Electrical 8 01-22-2009 01:13 PM
Recessed lighting, dimmer, compact fluerecents...anything special? gone_fishing Electrical 2 01-04-2009 08:35 PM
Track Lighting newbie questions GFW Electrical 1 04-18-2008 11:23 PM
Screw in Track Lighting Bar Popping Out SueC456 General DIY Discussions 5 03-13-2007 08:24 AM
Cable track lighting justtired Electrical 10 09-23-2006 01:53 AM
