Track Lighting With No Junction Box - Electrical - DIY Chatroom Home Improvement Forum
Old 09-20-2012, 08:16 AM   #1
Track lighting with no junction box
I'm trying to install track lighting in an area with no junction box, and there is not good place to install a junction box (duct work). Anyone know if a live end feed meant for conduit is suitable to be used as a junction box.
Example:
http://www.homedepot.ca/product/cond...n-white/992719
I notice is has a 1/2" knockout in it. Can I just install a romex clamp and make the connections in the little box? I'm assuming since it is meant for use with conduit, that the box is rated for connections inside it.
Any thoughts??
zubor is offline   Reply With Quote
Old 09-20-2012, 08:20 AM   #2
Master Electrician
Yup that's normally what you would use. Your track should have come with one.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
The Following User Says Thank You to andrew79 For This Useful Post:
zubor (09-20-2012)
Old 09-20-2012, 08:29 AM   #3
Thanks Andrew.
I want to install it on the ceiling. I am going to run NMD90 above the ceiling and then out through a small hole in the drywall where I want the track. Can I drill a 1/2" hole in the box on the "top" (side that is flush with the ceiling) and run the NM cable into it that way?
Old 09-20-2012, 08:46 AM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 484
There may be a KO on the bottom, but if you have to drill a hole, it needs to be 7/8 for the clamp to fit.
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
andrew79 (09-20-2012)
Dimmer for Halogen Track Lighting CompEngineer Electrical 2 12-04-2009 05:20 AM
Track Lighting Installation - No Electricty tazmajazz Electrical 11 10-19-2009 10:09 AM
LED track lighting feasible yet? GFW Electrical 8 01-22-2009 12:13 PM
Track Lighting newbie questions GFW Electrical 1 04-18-2008 10:23 PM
