Track Light Stopped Working - Electrical - DIY Chatroom Home Improvement Forum
Old 07-07-2012, 08:24 PM   #1
track light stopped working
We have a low voltage track system that was installed 3 years ago and worked fine until yesterday when it just won't turn on. We have used a tester to make sure the wires in the switch are still hot. And, tested the rail and wires the 3 pendants hang from and they are still hot too. Tried replacing one of the bulbs, and still no light. What could be the problem?
ACSD is offline   Reply With Quote
Old 07-07-2012, 08:36 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by ACSD View Post
...worked fine until yesterday
used a tester to make sure the wires in the switch are still hot. 120V?
tested the rail and wires 120V? 12V?
does each head have it's own transformer?
Old 07-07-2012, 09:47 PM   #3
One transformer converts 120v down to 20v for all three pendants.
Old 07-07-2012, 09:54 PM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
How did you test the rail?
Old 07-07-2012, 10:00 PM   #5
with the same tester we used on the wires. One of those that lights up when you touch it to the wire. It is not a voltage meter.
Old 07-07-2012, 10:02 PM   #6
k_buz's Avatar
I highly doubt you are getting a true reading. If all three lights went out at the same time, I'm betting the transformer went bad. You can either buy a multimeter and get an actual voltage reading, or just buy a new fixture.
Old 07-07-2012, 10:07 PM   #7
is the transformer in the fixture easy to replace?
Old 07-07-2012, 10:09 PM   #8
k_buz's Avatar
Possibly, but you might have to order it from the manufacturer of the fixture.
Old 07-07-2012, 10:10 PM   #9
It's an Alfa fixture and I understand they have gone out of business. Do you think the transformer may be available from another source?
Old 07-07-2012, 10:11 PM   #10
k_buz's Avatar
Technically you would need the exact same transformer that the fixture currently has or you will void the UL listing.
Old 07-07-2012, 10:27 PM   #11
Thank you very much for all your help!
Old 07-07-2012, 11:00 PM   #12
Alfa was a sub-brand of Juno Lighting Group. You could contact them and very possibly get a replacement transformer. But, if you aren't particularly attached to the fixture, you might as well take this as an opportunity to go get something you like.
LooseSCruz is offline   Reply With Quote
The Following 2 Users Say Thank You to LooseSCruz For This Useful Post:
ACSD (07-08-2012), zappa (07-08-2012)
Old 07-07-2012, 11:47 PM   #13
Trouble shooting low voltage "custom" rail fixture is easier that trying to thread a needle in an isolation tank with 20 oz boxing gloves on.
Take a photo of it and show dinner guests - under the light of a line voltage chandelier - what you used to have.
By the way, its the transformer...and you can always get a replacement. Just give the primary, and secondary voltages, along with the rated wattage required by all three lamps...(plus say 15 to 25% extra).
Kontoose.
PS. Its made in China - (the country - not the porcelain equivalent, that is).
kontoose is offline   Reply With Quote
The Following User Says Thank You to kontoose For This Useful Post:
ACSD (07-08-2012)
Circuit stopped working, breaker did not trip nr5667 Electrical 7 07-08-2012 04:31 AM
Light Switch Stopped Working mrwyant Electrical 3 06-04-2012 09:31 AM
110 and 220V plugs stopped working. hohadcr Electrical 11 11-02-2011 07:08 AM
Backyard light not working!!!! bigmike2 Electrical 59 02-23-2011 07:40 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 07:32 PM
