Old 08-16-2008, 12:28 PM   #1
sweaty
Track Light Can Trips Circuit When Rotated
In my office, I have track lighting- 7 cans on 2 switches, CFL's. When rotaing one can to redirect the light, it kept tripping the breaker. Now the bulb won't light. What is the problem?
sweaty is offline   Reply With Quote
Old 08-16-2008, 12:57 PM   #2
Send a message via AIM to theatretch85
Probably a broken wire inside the fixture that shorted out (and tripped the breaker). It might just be cheaper to buy a new one than to monkey around with fixing it; I think the last track light cans I bought were 8-10 dollars. To fix you need to have the cloth covered wire that is suitable for the heat produced in the can. Its possible the wire just simply came loose from the back of the socket and then shorted out, but it sound more like a broken wire.
theatretch85 is online now   Reply With Quote
Old 09-01-2008, 08:50 AM   #3
sweaty
I should not get a new can because all seven cans should match.
I am trying to take the can off. I've removed three screws and the trim. I cannot figure out how to get the can off. There is only a slot in it from which it hangs from a stem.
Any suggestions?
Microwave trips GFCI on a different circuit! Frank Kolwicz General Discussion 7 06-01-2008 09:48 PM
Can a GFCI protected light be installed into a normal light circuit? boongywoongy Electrical 6 05-19-2008 09:02 PM
Moved ceiling light in bedroom to center, now trips breaker blthomas Electrical 18 01-24-2008 05:29 PM
add a second light to an existing 3 way switch circuit djohns10 Electrical 6 03-02-2007 08:16 PM
Can You tap a 12 AWG circuit with 14 AWG for a light? jacksaly Electrical 5 02-27-2005 04:52 PM
