Tracing Wires From Circuit Breaker To Outlet/switch - Electrical - DIY Chatroom Home Improvement Forum
Old 11-15-2010, 11:21 AM   #1
Rewards Points: 150
Tracing wires from Circuit breaker to outlet/switch
I have opened up my walls and ceiling in the three bedrooms so that all wire is exposed. What is the best/easiest way to trace the lines? I have a Klein non contact electrical tester. "MY THOUGHT" was to kill one breaker at a time, then test lines to see which ones are dead and label with (orange/red/blue/green/etc electrical tape) We have the cbpanel upgraded and nothing is labeled? PLUS I want to replace all switches and outlets/ POSSIBLY wiring.
THANK YOU
Evil Scotsman is offline   Reply With Quote
Old 11-15-2010, 12:00 PM   #2
I have a tool (I forget where I got it) that plugs into an outlet and, apparently, sends a signal through the powerline. The tool includes a second item...a type of probe/reciever...that can detect the signal from the first item and identify which breaker power the plug into which the first item was installed.
I suspect a tool like this, assuming you can find one where you live or online, in conjunction with your non-contact voltage probe, could help speed up your circuit breaker identification process.
oberkc is offline   Reply With Quote
The Following User Says Thank You to oberkc For This Useful Post:
Evil Scotsman (11-15-2010)
Old 11-15-2010, 01:18 PM   #3
joed's Avatar
Rewards Points: 12,886
Plug in a radio. Turn it up loud. Go turn off breakers until you hear the radio go off.
Old 11-15-2010, 01:24 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 478
Make sure the batteries are out of the radio!!!
Don't ask!
jbfan is online now   Reply With Quote
Old 11-15-2010, 02:01 PM   #5
Rewards Points: 150
Gentlemen, Thank you! That is how I plan on getting started. But it looks like there are other outlets and switches that may be on the same breaker. For example there was an outlet in (what will be) my son's room and an outlet in (what will be) my office. But if I hadn't torn the walls downs wouldn't have known. What I am trying to do is identify EVERY outlet/switch on each breaker. Then label them in the cb panel.
Old 11-15-2010, 02:08 PM   #6
Yes. Unfortunately, I suspect it is a combination of tools and techniques that you will need to use. Or do as I do...don't bother performing a massive job at once. Wait until you need to know the circuit for a specific outlet or switch. Take your tool (radio with batteries, circuit identifier gizmo) and identify it, then write it down at that time.
Old 11-15-2010, 02:18 PM   #7
Rewards Points: 256
Radio work great for figuring out one outlet.
I do some property management: whenever I buy a home I male quick map of the home (not to scale).
I stand by the breaker box and have a friend go room by room and plug a tester into every outlet. I then flip switches until I get it right. Masking tape gets used to label every outlit and light in the whole house.
Then my help is free to go. I then get out the map and write numbers along the walls where the outlits are. I tape the map to the inside cover of the box and label the panels.
I also use a sharpie and mark every outlet cover, light figture,wire , etc as I work on them
michaelcherr is offline   Reply With Quote
Old 11-15-2010, 06:36 PM   #8
Electricians are pretty predictable and after you trace a couple circuits in your house you should know how the rest is wired. Just like plumbing expect that if two outlets are on opposite sides of the same wall they are probably fed by the same wire. Also expect outlets to be daisy chained not by what logically makes the most sense but by what uses the least ammount of wire.
chayce is offline   Reply With Quote
The Following User Says Thank You to chayce For This Useful Post:
Evil Scotsman (11-16-2010)
Old 11-16-2010, 05:38 AM   #9
Rewards Points: 150
Chayce, that is exactly what it appears to be, least amount of wire!
Circuit Breaker trips when I plug into an outlet Alex in Orlando Electrical 3 09-05-2010 01:04 AM
Switch triggering GFCI breaker on a DIFFERENT circuit stillmarried Electrical 5 11-29-2009 09:14 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Insulation around a electrical circuit breaker box terpsing Electrical 4 02-03-2009 03:08 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
