Tracing Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 11-09-2010, 06:29 PM   #1
Question
tracing wire
Is there any simple way for homeowner to trace an underground wire ?
Maybe renting?
14/2 UF no conduit
gbruhns is offline   Reply With Quote
Old 11-09-2010, 07:15 PM   #2
They do make toners for this sort of thing but to buy them is really expensive. You can try calling your local electrical supply house and see if they rent them. Here are some made by amprobe.
http://amprobe.com/cgi-bin/pdc/searc...&action=search
lordlondis is offline   Reply With Quote
Old 11-09-2010, 09:45 PM   #3
" Euro " electrician
frenchelectrican's Avatar
Otherwise you can get ahold of electrician some of them will have underground tracer unit for small fee for it and they will mark it down where it run and spot where the broken connection of the cable if need to.
I Have couple verison to use it and one can able go down deep as 2 to 3 meter deep { 6 to 9 Feet }
Typically most 2.5mm˛ twinners { 14-2 UF } typically buried about 12 to 18 inch deep as long it have RCD { GFCI } protected if not drop down to 18 to 24 inch deep { depending on your local area requirement }
Merci.
Marc
Old 11-09-2010, 10:50 PM   #4
Retired Electrician
I used a "finder" for years. Both in the electrical field and for a lot of plumbers that lost their pipes.....even found a septic tank (with a metal fish tape) that was not suppost to be there. It used a pulse wave (sender and reciever) (now I can't find anything because of old age) lol
Lsparky is offline   Reply With Quote
Old 11-09-2010, 11:03 PM   #5
I rented a signal tracer at a Building Center to find some pipes under my basement floor.
You could try wichin' rods also.
http://sepwww.stanford.edu/sep/jon/dowsing.html
Proper Use of Green Wire Nuts HooKooDooKu Electrical 16 06-29-2012 07:41 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
Burial wire and a seeming difference of opinion... SxS Electrical 19 02-24-2009 10:16 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 03:42 PM
