#16 |
Tracing what is on a circuit?
Thank you to everyone who posted. This some great info for me work from.
#17 |
Thank you again for all the responses. This past weekend I started tracing everything the was plugged into my circuits.
I did have a question about a 2 15 Amp Single Pole Tandem Breaker. I have two of these and found that most of my house is is on these breakers. How do these work? Do they act as a 20 AMP circuit? The 15 amp switches can be turned off one at time and are not connected. Thoughts? Thanks, David |
#18 |
Electrician
They act as 2 independent 15A breakers, but only occupy one breaker space in the panel. They are not the same as a 2-pole breaker, which must occupy two adjacent spaces in the panel. The do not act as a 20A circuit (to answer your question).
Kyle Just because you can, doesn't always mean you should |
| The Following User Says Thank You to SD515 For This Useful Post: | ostinoh (04-18-2011) |
#19 |
A "Handy Husband"
If you have a wall switch that controls a receptacle, I would take the feed to the fan off that receptacle. The problem with having a fan with only a remote is that if the remote battery dies or is lost, you resort to the pull chains on the fan (which I usually cut short when I install a remote).
| The Following User Says Thank You to rjniles For This Useful Post: | ostinoh (04-18-2011) |
| Display Modes | |
| open circuit unknown location / voltage leakage | fishmanflats | Electrical | 4 | 12-23-2009 10:04 PM |
| Home Theater Dedicated Circuit | rjschwar | Electrical | 20 | 12-16-2009 01:42 PM |
| Changing a 3 way circuit...using recessed lighting box as a junction box? | Oxymoron | Electrical | 1 | 12-07-2009 07:46 PM |
| Two Different Wire gages on Same Circuit OK? | Lovegasoline | Electrical | 5 | 12-02-2009 06:00 PM |
| Circuit out but circuit breaker didn't trip | PaulenAndrew | Electrical | 17 | 08-16-2008 09:38 AM |
