Tracing What Is On A Circuit? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-11-2011, 12:43 PM   #1
Tracing what is on a circuit?
Hello Ė
Iím planning the install of ceiling fans in our bed rooms. There is no current power source in the ceiling so I will need to pull off a current circuit.
What is the best way to find out how load is on that circuit so I can 1. Know that I can pull from it and 2. Donít overload it?
Regards,
David
ostinoh is offline   Reply With Quote
Old 04-11-2011, 01:03 PM   #2
Electrician
SD515's Avatar
Rewards Points: 504
To answer your question, turn off the breaker to the circuit you're thinking about using and see what all dies (lights, recepts, etc.) If your bedroom doesn't already have any ceiling light boxes, you must have some switched receptacles and a switch on the wall already? Are you wanting to keep those?
Kyle
Old 04-11-2011, 01:10 PM   #3
Thank you for the fast response..
I was planning on just using a remote for the fans and not worry about a switch since the fan is not going to have light with it.
We live in a house that was built in 1969 which is not old but I was concern with the load on the breakers since I cannot add any more breakers. The panel is full.
If I understand right a fan pulls about as much as a 100w light bulb?
Regards,
David
Old 04-11-2011, 02:17 PM   #4
Electrician
SD515's Avatar
Rewards Points: 504
Yeah, in general fans alone don't draw much...couple amps +/- If you find a circuit nearby that's lightly loaded, you should be ok. Just don't use the kitchen plug, laundry plug or bath plug circuits.
Kyle
Old 04-11-2011, 02:27 PM   #5
Great advice Thank you..
Is there anything special I need to do as far as wiring when just controlling it via a remote?
Regards
Old 04-11-2011, 02:40 PM   #6
Electrician
SD515's Avatar
Rewards Points: 504
Nothing special. Follow the instructions with the remote.
Kyle
The Following User Says Thank You to SD515 For This Useful Post:
ostinoh (04-11-2011)
Old 04-12-2011, 11:06 PM   #7
Why not use those circuits?
I "mapped" my whole house buy pulling a breaker or a fuse (I have 2 sub panels) and checking each outlet or light individually. Annoying as heck to reset all the clocks on things but now it's all mapped out.
V
Vincer is offline   Reply With Quote
Old 04-13-2011, 12:58 AM   #8
Scared Electrician
Saturday Cowboy's Avatar
code says you can't use those circuits for any thing else.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 04-13-2011, 01:48 AM   #9
OK gotcha! I was planning to wire in a new outlet for an aquarium and was thinking of tapping into the kitchen plugs, I'll rethink my plan, thanks!
Vince
Old 04-13-2011, 08:39 AM   #10
Just call me Andrew
Rewards Points: 1,020
You can't tap into kitchen counter plugs for anything else. You can tap into a circuit that has outlets elsewhere in the kitchen...but if the fridge is on it, i wouldn't.
Andrew
secutanudu is offline   Reply With Quote
Old 04-13-2011, 09:07 AM   #11
Electrician
SD515's Avatar
Rewards Points: 504
By code you can't tap into the kitchen small appliance receptacle circuits, counter top or not, for use in any other room except pantry, dining rm, nook, similar area, etc.
The small appliance circuits are for the receptacles only, and only in one kitchen & associated rooms.
Kyle
secutanudu (04-13-2011)
Old 04-13-2011, 09:08 AM   #12
Just call me Andrew
By code you can't tap into the kitchen receptacle circuits, counter top or not, for use in any other room except pantry, dining rm, nook, similar area, etc.
I didn't know that.
Andrew
Old 04-13-2011, 09:30 AM   #13
Electrician
SD515's Avatar
Rewards Points: 504
That's cool. The key thing is whether it's a SABC or not. Usually any kitchen recept is on a SABC. I know...in a perfect world.
Kyle
Old 04-13-2011, 01:27 PM   #14
Is there any one better tool to test my plugs to see if they are hot besides holding a lamp and plugging it in to test?
Once I map out the items that are on that circuit then I use the math of figuring out the watts?
Old 04-13-2011, 01:39 PM   #15
Rewards Points: 22
I generally use a circuit tester for that; the small ones that plug into the receptacle. They have 3 lights, indicating whether the receptacle is wired properly, and if not, where the problem is, so you can accomplish two tasks at one time. A few bucks at any hardware or home center, and they fit in the palm of your hand, so easier to carry around than a lamp. Every DIY'er should have one anyway.
Yes, as for the rest of it, do the math. Just don't overlook things like attic or crawl space lights, gable vent fans, etc., just to name a few, as they can be easy to miss sometimes.
The Following User Says Thank You to DexterII For This Useful Post:
ostinoh (04-13-2011)
open circuit unknown location / voltage leakage fishmanflats Electrical 4 12-23-2009 10:04 PM
Home Theater Dedicated Circuit rjschwar Electrical 20 12-16-2009 01:42 PM
Changing a 3 way circuit...using recessed lighting box as a junction box? Oxymoron Electrical 1 12-07-2009 07:46 PM
Two Different Wire gages on Same Circuit OK? Lovegasoline Electrical 5 12-02-2009 06:00 PM
Circuit out but circuit breaker didn't trip PaulenAndrew Electrical 17 08-16-2008 09:38 AM
