Tracing A Light Switch To An Outlet - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-21-2006, 03:33 PM   #16
spam33, are there wire nuts inside the box? on the hot wires? If not then the above responses are not correct. Still thinking about what might be going on with your receptacles.
Sparky Joe is offline   Reply With Quote
Old 07-24-2006, 01:26 PM   #17
Well, it sucks, but I had to give up on this project. I now have a better understanding of how these things should be wired, but in this case it was a bit too risky for me to play around.
I cannot see any wire nuts inside the box, but I'm pretty sure they're probably located somewhere in the walls. If the wire setup was a bit more standardized, I might have been able to figure it out. Oh well!
I went ahead and purchased one of those remote light switches. I installed it right where the old one used to be (after putting a wire nut on each of the old cables), and it's working like a charm now. Thanks for all your help and for sticking through this whole's a shame we couldn't figure this one out.
spam33 is offline   Reply With Quote
Old 07-24-2006, 03:57 PM   #18
Originally Posted by spam33
I pulled the tab to see what would happen, and the switch sort of worked. The bottom plug became an "always hot" outlet, and the top plug turned on and off with the switch. The problem is, now the next three plugs in the run also turn on and off at the switch. I assume this can easily be fixed by adjusting one or two of the wires. Any ideas as to which ones?
Thanks again!!!
Swap the black wire from the top to the bottom of the outlet and the bottom black wire to the top.
redline is offline   Reply With Quote
Help with outlet controlled by switch craigpall Electrical 2 05-18-2008 08:08 AM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 09:44 PM
Outlet controlled by switch Shardi Electrical 4 10-09-2005 06:24 PM
trying to wire a light and light switch off of an outlet imphishy Electrical 3 03-16-2005 09:04 PM
installing a light fixture on a switch controlled outlet Unregistered Electrical 1 02-24-2004 10:51 PM
