TR vs. TR+WR outlets
So I replaced those 5 receptacles outside my house. However, unfamiliar with recent code for WR receptacles, I use just TR receptacles. However, all receptacles are covered. I even replaced the metal J-boxes since they were starting to oxidize after 29 years and rubber gaskets were dried out/cracked. Even some of the outlets I pulled out were almost completely rotted/rusted and 2 of the 3 of them cracked.
I should be okay right? I know they're not TR+WR receptacles but the issue is that the circuit breaker is GFI. Rather than switch to standard breaker and buy all new GFCI WR+TR outlets for an added cost, I'd just stick with TR since the breaker/circuit is already GFI protected. Also, all outlets are covered for both uses in wet rain/snow, etc.
Thanks,
~Skelleyman
