Towel Warmer Above Tub - Electrical - DIY Chatroom Home Improvement Forum
Old 05-12-2011, 03:59 PM   #1
I am trying to figure out the best place for a wall mounted towel warmer in my bathroom for our remodel. I would like to place the towel warmer at the foot or head of the tub, but the place where it is going does not allow for much space between the wall and the rim of the tub. I know that you can't have an outlet "directly over a bathtub" but I'm not sure how much space is needed between the outer rim of the tub and the wall with the outlet on it. If there is a couple inches of decking between the rim of the tub and the wall is this ok? If not, would a hard wired towel warmer be ok at this location?
I am assuming I don't need a didicated circuit for the towel warmer, I can just tie it to the GFCI outlets in the bathroom correct? I think these pull less than an amp as the ones I've been looking at are in the 80 watt range.
Thanks,
Richard
rjschwar is offline   Reply With Quote
Old 05-12-2011, 04:48 PM   #2
Master Electrician
Rewards Points: 3,916
By code, as long as the receptacle is outside the footprint of the tub it is code compliant--GFCI protected of course.
brric is offline   Reply With Quote
Old 05-12-2011, 05:21 PM   #3
Perfect. That is what I was hoping.
Thanks,
Richard
Towel Warmer mbs5689 Interior Decorating 1 03-05-2011 08:15 AM
Hydronic Towel warmer install question bigbluedude HVAC 5 02-13-2010 07:02 AM
Towel rod and toilet paper holder dnbreaks Remodeling 4 01-30-2010 03:24 PM
bathroom towel racks ramonakc Interior Decorating 5 04-19-2009 01:59 AM
Question on Hanging Towel Racks sbattisti Interior Decorating 13 02-17-2009 11:24 AM
