Touching The Service Neutral - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-04-2008, 12:51 PM   #16
Rewards Points: 2,350
Originally Posted by CowboyAndy View Post
Okay, i re read your post and it makes sense now.
Yes, I was talking about where the neutral comes in from the POCO and attaches to the lug in the main panelboard.
When there is a load on a circuit, the current travels on the hot and neutral conductors. A single light bulb is a series circuit, that is, the light bulb is in series with the hot and neutral. The voltage drop is 100%. The potential on one side is 120 V. On the other side, it is 0 V. If you open the neutral, the load stops working, and there is no voltage drop. The neutral from the dead light bulb is now at 120 V. If you get between the neutral from the bulb and the neutral from the circuit, you are now part of the circuit, so you and the bulb will share an amount of current proportional to the applied voltage and inversely proportional to the combined resistance of both you and the bulb.
VOLTAGE DROPS ONLY WHEN CURRENT FLOWS. No current flow, no voltage drop. No voltage drop means the potential exists for current to flow through anything that completes the path.
InPhase277
Old 03-05-2008, 11:56 AM   #17
When is fishing season?
CowboyAndy's Avatar
Thanks for the great explination guys.
Each day it gets clearer and clearer.
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Sub panel grounding sluggermike Electrical 27 11-11-2007 01:23 AM
200 amp panel with a 100 amp service? alexz Electrical 10 07-29-2007 10:00 PM
Suspected open/loose service neutral mrtomwj Electrical 5 09-28-2006 08:46 AM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 05:54 AM
