Touching The Service Neutral - Electrical - DIY Chatroom Home Improvement Forum
Old 03-03-2008, 08:07 AM   #1
When is fishing season?
CowboyAndy's Avatar
Touching the service neutral
Okay, so if there is something in the house drawing current, shouldn't there be voltage travelling through the neutral? Working in a live box saturday, I was awefully close to the bare service neutral. What would happen if I touched it with bare hands? with something metal? something grounded?
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 03-03-2008, 08:50 AM   #2
electrician
Your conception of voltage and current are wrong. Voltage isn't flowing through the neutral, current is. What would happen if you touched the neutral, nothing would happen if it was installed and bonded correctly. It would be the same as touching the cover of your panel, the sides of your panel, any grounded metal object in your house, taking a shower or washing your hands. The neutral is bonded to your grounding system making everything connected to it the same potential. Current can't flow without a difference in potential.
Assuming that your house is properly grounded and bonded.
Now that being said, don't just grap any neutral because if it isn't landed you could complete a path back to ground and get zapped. One of the worst shocks I ever had was off a switched neutral, homeowners work.
Silk is offline   Reply With Quote
Old 03-03-2008, 04:36 PM   #3
Rewards Points: 870
Excellent explaination, Silk.
LawnGuyLandSparky is offline   Reply With Quote
Old 03-03-2008, 07:49 PM   #4
The neutral is referred to as the "grounded conductor" because, although it is conducting current, it is grounded.
Like Silk said, as long as the grounded path back to the source is complete, the electrons will choose that path. If it gets interrupted, they will find another way and you do NOT want it to be through you. Human bodies DO conduct electricity, just not very efficiently.
220/221 is offline   Reply With Quote
Old 03-03-2008, 08:58 PM   #5
The only person I ever witnessed locked on an electrical shock was with a (so-called) harmless neutral.
The only way to safely separate the two is to knock the ladder out from under them.
NAIL is offline   Reply With Quote
Old 03-03-2008, 09:02 PM   #6
Rewards Points: 2,350
This would happen if he opened a neutral and placed himself between the line and load. At that point, one side ceases to be a neutral and becomes a hot.
InPhase277
Old 03-03-2008, 09:30 PM   #7
Yes, but the thought it was a harmless neutral.
Old 03-03-2008, 09:35 PM   #8
Res Ipsa Loquitur
As Silk stated earlier- don't just grap any neutral because if it isn't landed you could complete a path back to ground and get zapped. It wasn't landed and he was in the path back to ground.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 03-04-2008, 06:46 AM   #9
CowboyAndy's Avatar
So basiclly the moral of the story is never assume that a neutral doesn not have current flowing through it?
On a somewhat related note, when you have say a light on a switch that is gfi protected, with the cct live but the switch off, and you clip the neutral going to the light why does the gfi trip?
MY HOUSE OWNS ME!
Old 03-04-2008, 08:12 AM   #10
electrician
No, you shouldn't care if the neutral has current flowing through it or not. You should care if it is at the same potential (voltage) as earth and the rest of your groundng and bonding system, which should be zero.
In reality it should be the same potential as your grounding and bonding system, but earth is another matter, for another day.
Old 03-04-2008, 08:21 AM   #11
CowboyAndy's Avatar
Okay, I am confused by your statment that a person shouldn't care about current or vontage. If there is ever a potential, then shouldn't someone always be concerned about it?
MY HOUSE OWNS ME!
Old 03-04-2008, 08:28 AM   #12
GFCI workings
CowboyAndy, check out this site. http://home.howstuffworks.com/question117.htm
RobertS is offline   Reply With Quote
Old 03-04-2008, 09:10 AM   #13
electrician
I never said you shouldn't be concerned about voltage, actually I said the exact opposite. You are confusing the terms voltage, current and potential. First thing is to learn what the difference between voltage and current is.
Old 03-04-2008, 09:21 AM   #14
electrician
Just to clarify, in your original post when you talked about "almost touching a bare service neutral", you were talking about the neutral lug on you lighting panel, right? Was the neutral landed? I assumed this was an existing, working panel.
Old 03-04-2008, 09:45 AM   #15
CowboyAndy's Avatar
Okay, i re read your post and it makes sense now.
Yes, I was talking about where the neutral comes in from the POCO and attaches to the lug in the main panelboard.
MY HOUSE OWNS ME!
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Sub panel grounding sluggermike Electrical 27 11-11-2007 02:23 AM
200 amp panel with a 100 amp service? alexz Electrical 10 07-29-2007 11:00 PM
Suspected open/loose service neutral mrtomwj Electrical 5 09-28-2006 09:46 AM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 06:54 AM
