Touch-Sensitive Switch For Lamp - Electrical - DIY Chatroom Home Improvement Forum
Old 11-25-2007, 07:28 AM   #1
Touch-Sensitive Switch for Lamp
Hello, i'm doing an A-Level in Design and Technology and i have to make a light, and electrics really isn't my strong point. I would like to use a touch sensitive pad of some sort to turn my lamp on and off. What would this entail? and also where could i get this, or anything similar?
Thanks, Alex
alext131 is offline   Reply With Quote
Old 11-25-2007, 07:45 PM   #2
Union Electrician
goose134's Avatar
Not sure if this is what you are thinking of but: http://www.comforthouse.com/nofumswit.html
It allows the metallic portion of the lamp to be used as the on/off. I believe they also make them in three way lamp styles for varying the light levels.
goose134 is offline   Reply With Quote
Old 11-25-2007, 10:57 PM   #3
touch sensitive
Ive got these on several of my lights in my older house. They can be a bit quirky but I have old electrical. Home Depot sells several styles. One plugs into the wall and the light plugs into it, one screws into the light which then screws into the fixture and the third actually wires into the base. I chose the last one, more work but more seemless design!
chewy is offline   Reply With Quote
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 09:34 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
Wall-mounted touch switch lamp help davros72 Electrical 1 12-24-2006 01:13 PM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 03:52 PM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 02:53 PM
