Total Of Circuit Breakers - Electrical - DIY Chatroom Home Improvement Forum
Old 05-11-2010, 05:56 PM   #1
Total of Circuit Breakers
I have a 200 amp panel. On the 110v side, is it acceptable by code for the sum of the breakers to exceed 200 amps? I have more than 10 lines coming into the box (15 actually) and would like to consider using 5 tandem breakers, but the total of the breakers would add up to more than 200 amps. I have considered running two wires into a wire nut and then some pigtails into existing breakers. Basically, which would be better??
xraydido is offline   Reply With Quote
Old 05-11-2010, 06:03 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 424
The sum of the breakers mean nothing.
Before adding tandoms, you must make sure your panel will accept them.
What model panel do you have?
Old 05-11-2010, 06:26 PM   #3
It is a Siemens and I know that it will take tandems. Any opinion on which is better - tandems or wire nutting two lines to a pigtail - or is it just a matter of perference?
Old 05-11-2010, 07:09 PM   #4
Question
Quality wise it's the same. There is no difference. But on a tandem breaker, you'll get a few extra amps. (But common sense tells not to use any of the tandems to the max. Especially continuous loads. Even when the load calculations meet code requirements. Because after all, the tap from the Bus bar is designed for one breaker.!
spark plug is offline   Reply With Quote
Old 05-11-2010, 07:14 PM   #5
Licensed electrician
Rewards Points: 1,506
A tandem is two breakers in one housing. This would allow two circuits in the space of one.
Pigtails are used to combine two wires.
Old 05-11-2010, 07:48 PM   #6
Smile
Yes, JP. I'm aware of that. I pointed out to the OP that with a tandem breaker you get the advantage of an extra breaker (as opposed to just pigtailing two circuits to one breaker. There's no need (on my part) to repeat the rest of what I said about Tandem breakers. Because I have nothing to add at this time.!
Last edited by spark plug; 05-11-2010 at 07:49 PM. Reason: Missing letter/word (I).
Old 05-11-2010, 08:25 PM   #7
My reply was to the OP. They seemed confused between pigtailing and a tandem.
Old 05-12-2010, 12:11 PM   #8
not confused, just want to know if either one is preferred. sounds like it is 6 of one / 1/2 dozen the other. i had a home inspection that picked up a few breakers with double taps - i did the repair using the pigtail method - i just wanted to know if using tandems (and thereby exceeding 200 amps of circuit breakers on the 110 side) was acceptable - it sounds like my existing repair is just as good as inserting tandems.
Old 05-12-2010, 01:46 PM   #9
# of breakers = # of 'home runs'.
Old 05-12-2010, 02:27 PM   #10
?????? But what is his batting average ??????
Old 05-12-2010, 04:03 PM   #11
TBD
Old 05-12-2010, 08:07 PM   #12
Red face
Square D does have one type of breaker (don't know the model#) that is not a tandem breaker, where you can officially connect Two wires to one terminal. (The terminal having a slot on both ends.)
On the subject of inserting more breakers that will exceed the total amperage. Why it is permitted. It is based on the fact that you (no one) will not use all the lights and equipment to the max. load at the same time. This is an issue that is confusing to most people who are not electricians. I had a customer (of a 1-Family residence) who argued with the utility (Con-Ed) rep. why they didn't increase his Service beyond 200 Amps. (The max. for residential service.) (Highly confusing)!
Last edited by spark plug; 05-12-2010 at 08:09 PM. Reason: Missing letter/word (a).
Old 05-12-2010, 08:41 PM   #13
kbsparky's Avatar
Originally Posted by spark plug View Post
.... I had a customer (of a 1-Family residence) who argued with the utility (Con-Ed) rep. why they didn't increase his Service beyond 200 Amps. (The max. for residential service.) (Highly confusing)!
Did they tell him that if he needed that much juice he probably could not afford the electric bill?
-KB
Old 05-12-2010, 09:03 PM   #14
Hey, I was considering an upgrade to 320a based on my Christmas display
And, I "know" people on Christmas sites who have 400a JUST for their display
Old 05-13-2010, 03:30 AM   #15
kbsparky's Avatar
And how does the electric bill for December compare to the rest of the year?
-KB
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 03:34 PM
Checking circuit load for recessed lighting Nathan0115 Electrical 12 05-07-2010 03:49 PM
One Circuit / Two Breakers? tjeieio Electrical 5 01-15-2010 05:50 PM
open circuit unknown location / voltage leakage fishmanflats Electrical 4 12-23-2009 09:04 PM
circuit breakers Yoyizit Electrical 4 02-18-2009 09:46 AM
