-   -   Torque on a receptacle screw? (http://www.diychatroom.com/f18/torque-receptacle-screw-39663/)
Ultrarunner2017 03-04-2009 10:49 PM
Hi;
I had to change an outdoor receptacle today. When I was installing the new one, a Leviton BR15, I managed to strip the screw or the threads in the terminal nut for the back-wiring.
I was just using a standard screwdriver, nothing really big. It didn't feel like I was putting too much torque on the screw, but I guess I was.
After that, I just side-wired using the same receptacle, using the other screw (nice that there are two hots and neutrals<g>).
Now, I've always had trouble knowing how tight to make things like this. Since I was a teenager, I found that I seem to have a lot of torque in my arms/wrists.
Is there a such tool as a torque screwdriver that I could buy, and if so, how much torque should these screws get?
I really don't like the back wiring anyway, since you can't see the actual connection, and I have had issues with wires pulling out of some of the Leviton GFCI receptacles.
I am going to side-wire all of them from now on.
Thanks for your advice.
FW
jbfan 03-04-2009 11:07 PM
Here is one from Sears, but others make them.
http://www.sears.com/shc/s/p_10153_1...orque+Wrenches
jamiedolan 03-04-2009 11:54 PM
Wow that is pricey $$$.
Considering a regular "automotive" type of torque wrench is less than $20.
Jamie
Ultrarunner2017 03-05-2009 06:47 AM
Sure is. I thought the $80 for a general purpose torque wrench was high.
Well, to be sure, I'm not going to spend $150 on the tool just to spare the occasional inconvenience of stripping out small screws/nuts.
I think I'm just going to have to stop eating so much spinach:laughing:
The receptacle I was installing was the commercial/residential model. I doubt that I would have had the same problem with the industrial.
In any case, I could not find a torqing spec for it. I've read here about proper torque on large lugs, like the main breaker, but never for a receptacle.
FW
Billy_Bob 03-05-2009 08:43 AM
Here is a Leviton hospital grade outlet which says "Designed torque capability of +20 inch pounds."
(Page 4)
http://www.leviton.com/OA_HTML/ibcGe...BE&appName=IBE
And I would assume 12 inch pounds = 1 foot pound?
darren 03-05-2009 05:27 PM
Maybe it comes with practice but I have never really had an issue with it before.
My favorite way to do plugs, especially if i have alot to do is to set the clutch on my drill around 3 and 4. Then i just give it on the trigger and when the clutch kicks in the screw is plenty tight.
Yoyizit 03-05-2009 06:44 PM
http://www.engineersedge.com/torque_table_sae.htm
InPhase277 03-05-2009 08:29 PM
The correct torque is about 1/4 turn past where the screw contacts the wire against the back plate. As far as I'm concerned, there really is no reason to have a torque screwdriver for devices. Breakers maybe... but not devices.
Billy_Bob 03-06-2009 11:33 AM
I've always thought it silly to have a torque value for outlet screws, however since reading this topic, I do see a use for it and that is "King Kong men" (one of which I work with sometimes) who tighten things TOO tight to the point the screw strips or breaks.
I was doing some axle work with this guy recently and handed him a torque wrench set to 90 ft. lbs. I said tighten until it clicks. It clicked right away and he looked bewildered - said "Shouldn't it be tighter than that?"
I said "NO!"
jamiedolan 03-06-2009 01:26 PM
FW
I use a regular #1 square drive to tighten outlet and have never broke one or had the wires feel loose. But I always but the "expensive" outlets.
Jamie
oregondiy 03-06-2009 04:10 PM
Jamie
Wow a $20 torque wrench, I wouldn't trust that, considering my regular automotive type torque wrench cost over $400, could have even been $500, I try not to think about it
Ultrarunner2017 03-06-2009 07:28 PM
Jamie
That's what I was using. Problem is I could not see the wiring clamp inside the receptacle.
I'm just going to side-wire from now on. Never had a problem with them.
FW
jamiedolan 03-06-2009 07:59 PM
FW
So it was one of the hidden type of clamps like you see on many of the GFCI outlets?
The P&S outlets that I really like the clamps on are exposed on the side, just like a regular side wire screw, but it has a clamp on it. Unlike the clamps on many GFCI's which I would sometimes rate as having an "average" hold on the wire, these really "clamp-down" the way a breaker does.
Hard to beat using the regular side wire outlets for a secure hold(just more work), I use my small long nose Kliens to wrap the wire tight around the screw, then if it is a smidgen long, I snip the end of it off after it is warped around the screw, with a sharp snips.
Jamie
Ultrarunner2017 03-09-2009 04:35 PM
Jamie
That's what I like to do with side wired. I don't have the correct snips though. Mine are very dull, and do not have a small enough nose to get to the wire at the screw. They're on my next "Klein tool to buy" list<g>
FW
