Torque Of Electric Motor Brake - Electrical - DIY Chatroom Home Improvement Forum
Old 06-15-2012, 04:45 PM   #1
Question
Torque of electric motor brake
I have an old Stearns motor brake that holds up a heavy attic ladder (staircase) when the power is off. It is 1.5 ft-lb and 115 VAC. It is not holding the weight of the ladder very well. I've tried adjusting the solenoid air gap, torque spring and it still slips.
Would it hurt if I replaced the brake to a 3 ft-lb model? Any other ideas to solve the problem?
Thanks for any recommendations!!
StanfromVan is offline   Reply With Quote
Old 06-15-2012, 06:31 PM   #2
Idiot Emeritus
Rewards Points: 1,492
If you can make it fit, you can put any size brake you want on the ladder.
The current of a brake like this is very low, and they can be run continuously.
Rob
micromind is offline   Reply With Quote
Old 06-15-2012, 07:41 PM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,990
You can replace the brake, or you may also be able to adjust other parts of the system to make it work better. For example, if the brake is on the motor shaft and the lift is connected via a belt drive, you could change the belt drive ratio to decrease the torque on the motor so it holds.
mpoulton is offline   Reply With Quote
Old 06-16-2012, 07:20 AM   #4
Rewards Points: 826
I am not familiar with this type of mechanism but I know with garage doors if the opener isn't working properly its often the door springs aren't set right.
Does this system have a counter weight or spring? Maybe that isn't holding enough of the load putting too much onto the brake. Maybe cable mechanism to the weight spring is sticking? Just a thought.
curiousB is offline   Reply With Quote
Old 06-16-2012, 09:41 AM   #5
Unless the ladder has gotten heavier, a working 1.5 lb-ft brake should do the job.
http://www.stearnsbrake.net/
http://stearns.rexnord.com/products/install.asp
You could also check the power to the old unit, including current draw, assuming that when the brake is engaged it is drawing power and not the other way around. If it is the other way around then all you may need is a new spring.
Tags
ac brake , motor brake , stearns , torque
electric versus propane water heater Jeremy Hillary Boob, PhD Appliances 7 01-30-2012 05:23 PM
Water heater - Gas or Electric Sartrean Appliances 17 01-13-2012 04:45 PM
90 amp electric car charger! The future... Billy_Bob Electrical 16 02-16-2010 02:01 PM
