Torque - Electrical - DIY Chatroom Home Improvement Forum
Old 03-26-2008, 07:04 PM   #1
Master Of Nothing
mr500's Avatar
Torque
When installing breakers and such, I know that there are torque specs, but Im just wondering how many actually torque the wires as opposed to tightening really good?
I have torque wrenches lol that would do the job, but is it overkill?? Just a newbie question is all.
Im Not An Electrician...But I Did Stay At A Holiday Inn Express Last Night!!
mr500 is offline   Reply With Quote
Old 03-26-2008, 07:12 PM   #2
Res Ipsa Loquitur
I would suggest to try a few times with a (not-in-use!) receptacle and a few pieces of 12g and 14g wire on the screw terminals to get the feel right. Once you know what to expect just continue that amount of tightness for other fittings. When the wire is tightened down, there should be no movement under the screw if you wiggle the wire. It depends on your hand and forearm strength to get it just right for you without using torqueing tools.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 03-26-2008, 07:45 PM   #3
Idiot Emeritus
Rewards Points: 1,492
With basic breakers, switches, recptacles and such I don't bother with a torque wrench. Even big wire lugs. Just tighten them down. I've broken enough screws and stripped out enough lugs over the years that I've get a pretty good idea just how far I can go.
With switchgear, especially medium voltage (over 600V, less than 35,000V), the bus splice plates, breaker mounting fingers, etc. always get torqued to specs. Usually a 'click type' torque wrench. Some engineers even want a calibration certificate on the torque wrench.
Rob
micromind is offline   Reply With Quote
Old 03-26-2008, 08:57 PM   #4
Union Electrician
goose134's Avatar
I use a torque wrench on any lug in a panel, switchgear, transformer and the like. Switches and receptacles I've never really bothered with, you can get the feel. I've only seen a torqueing screwdriver ONCE. I could not believe how much he said it cost. About $120.
The torque wrench provides you with the peace of mind that you are tightening things to specs. Not guessing. I've seen too many guys who think "gorilla tight" is an acceptable method of tightening lugs. They also seem surprised when they strip them.
goose134 is offline   Reply With Quote
Old 03-26-2008, 10:05 PM   #5
Rewards Points: 2,350
My elbow pops when the right torque is reached...
InPhase277
Old 03-26-2008, 10:10 PM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 464
InPhase277
My elbow pops when I get up in the morning!
jbfan is online now   Reply With Quote
Old 03-26-2008, 10:16 PM   #7
So you're always torqued?
InPhase277
Old 03-26-2008, 10:54 PM   #8
jbfan's Avatar
Rewards Points: 464
InPhase277
You bet. Every morning when the clock goes off!
Old 03-26-2008, 11:31 PM   #9
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
I use the grunt technique. One ughhhh is just about right. Two is pushing it.
I threw my clock away on 1/01/07.
Old 03-27-2008, 10:51 AM   #10
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
You beat me by 2 days. Now I work for me and I am never worried about being late. No need for a clock. I have a great boss.
jrclen is offline   Reply With Quote
Flywheel Censor On '96 Jeep Cherokee bobo60 Automotive Repairs 1 12-05-2007 11:39 AM
A torque question wavebuy1 Automotive Repairs 3 09-28-2007 03:17 PM
