Tore Romex Sheathing Under A Staple....replace The Whole Wire? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-01-2010, 09:40 PM   #1
Tore Romex Sheathing Under a Staple....replace the whole wire?
I am rewiring my second floor and I'm using big metal staples to secure the wire to the side of joists in the attic. It is the type of staple that you hammer in and it has a little plastic piece that is supposed to protect the wire from getting cut by the metal staple. I had to remove one and in the process I tore a small hole in the yellow sheath of the romex 12-2 cable. It did not damage the internal wires. Do I need to replace the whole section of cable or can I just tape it up?
jerseyguy1996 is offline   Reply With Quote
Old 11-01-2010, 09:53 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
No, electrical tape is a perfectly fine repair for this. Just make sure you cover the nicked ares with several smooth wraps.
The Following User Says Thank You to Speedy Petey For This Useful Post:
jerseyguy1996 (11-01-2010)
Old 11-01-2010, 09:56 PM   #3
That is a load off of my chest. That wire was tough to fish up through the wall.
Old 11-01-2010, 10:16 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
It's always easier the second time. You already have a pull line (the bad NM) to use to pull in the new NM.
Old 11-01-2010, 10:21 PM   #5
Nap, you'd replace a whole home run for a small tear in the sheathing?
Old 11-01-2010, 10:47 PM   #6
nap
You talking to me?
nap's Avatar
no no no, didn't mean to infer that. Merely commenting on the OP's lack of being thrilled if he did have to replace it.
Nope, as long as the actual insulation on the wire wasn't damaged, a little 33+ and he is good to go.
# of Romex cables per staple? Tra Electrical 1 10-04-2010 01:21 PM
exterior sheathing - keep it or replace it? derf36 Building & Construction 12 08-04-2009 11:19 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 02:14 PM
damaged wire sheathing rodeo Electrical 11 12-28-2007 10:11 PM
wire staple removal madmax55555 Electrical 8 07-03-2006 06:29 PM
