Old 06-27-2008, 09:02 AM   #1
Top receptical not working
In one room, the TOP plug on 3 recepticals just quit working. The bottom plug has power and working.
any suggestions?
DIYVa is offline   Reply With Quote
Old 06-27-2008, 09:16 AM   #2
Electrical Contractor
Sounds like a wall switch is off or bad.
hpp58 is offline   Reply With Quote
Old 06-27-2008, 10:17 AM   #3
Wall switch?...does a wall switch control the TOP recepticle?
Old 06-27-2008, 10:20 AM   #4
Licensed Pro
Or bottom, depends on who installed the circuit.
Old 06-28-2008, 12:41 AM   #5
Many, (if not all), wall outlets have a small tab that connects the two "hot" terminals together. This tab is designed so that you can put a flat-blade screwdriver into it and break it off so that the two outlets can be isolated. (So one can be controlled by a light switch.)
Its possible that the "tab" has broken free from age or . . . something.
Artie2 is offline   Reply With Quote
Old 06-28-2008, 07:19 AM   #6
wirenut1110's Avatar
Send a message via AIM to wirenut1110
Especially if it's a newer house and these receptacles are under or close to a window, they do this for Christmas lights.
wirenut1110 is offline   Reply With Quote
Power Washer Chem Feed Not Working robertr4836 Tools 11 11-24-2012 09:43 PM
Working with granite... SDeeter19464 Remodeling 5 06-14-2008 06:51 AM
GE fridge evaporator fan change and still not working Trish Appliances 2 03-30-2008 02:47 PM
three-way only working on one switch amydawn Electrical 11 07-11-2006 06:52 PM
Furnace stops working once a day - help Da_Bears HVAC 2 01-26-2006 02:19 PM
