Toolmandave - Electrical - DIY Chatroom Home Improvement Forum
Old 10-31-2010, 04:36 PM   #1
toolmandave
I have an older home that has 100 Amp. service, what I am trying to do, is tap off my panel box in the basement, using the old 240 volt (40) amp breaker---then running it underground to my garage, where I have installed a Square D QOC32UF 100 amp load center. Will this work? Will I get enough current? Will a 100 amp panel box draw too much current for a 40 amp. breaker?
toolmandave is offline   Reply With Quote
Old 10-31-2010, 05:34 PM   #2
Electrical Contractor
kbsparky's Avatar
First: QOC32UF is the catalog number for the panel cover ...
2nd: What is your anticipated load out in the garage? A few lights, maybe a power tool or 2, or a ceramic shop with a couple of kilns?
-KB
Old 11-01-2010, 07:10 AM   #3
Rewards Points: 1,514
You can run it off of your 40 amp breaker for now provided you don't turn on too many things in the garage at the same time.
If you run #2 copper wires (3 conductors and ground) to the subpanel, you can later upgrade the breaker in the main house, possibly requiring upgrading the entire service, and then have 100 amps out there.
Old 11-01-2010, 08:14 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,370
Ayuh,... You'll have about 40 amps available,...
The 100 amp breaker will just be along for the ride, as the 40 amp breaker will trip long before the 100 amp will...
As long as you don't draw more than the 40 amps,... It'll work just Fine...
Bondo is online now   Reply With Quote
The Following User Says Thank You to Bondo For This Useful Post:
toolmandave (11-03-2010)
Old 11-03-2010, 09:01 AM   #5
Thanks, It's just nice to have someone else confirm your "guesses" sometimes. Dave.....
