Took Down My Ceiling Fan And Found Something That I Think Is Odd. . . . - Electrical - DIY Chatroom Home Improvement Forum
Old 01-19-2012, 12:15 AM   #1
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Took down my ceiling fan and found something that I think is odd. . . .
3 wires entering the light box (metal) in the ceiling. Two of them are the old cloth wrapped romex cable and i'm not sure yet where they go (that stuff is bad right?) One of them is some other kind of romex with a black jacket that I haven't seen before (this is the one that runs down to the switch). The jacket is similar to any of the other yellow or white stuff I've seen.
Anyway my boggle is this :
The two neutral wires from the cloth romex were wire nutted together and connected to the neutral on the ceiling fan.
The hot lead from the wire going to the switch was going directly to the ceiling fan's black wire.
The hot leads from the cloth wrapped romex were wire nutted together WITH the neutral from the wire that runs into the switch.
This seems wrong to me.
Any good reason it would be this way?
Grounds were all connected together and bonded to the metal box, just for the record.
Journeyman Plumber
Old 01-19-2012, 12:20 AM   #2
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Switches don't need neutral they are using it as constant hot to the switch. Like so ... it's called a switch loop. The second image is onward power in the same configuration which is what you probably have.
Took down my ceiling fan and found something that I think is odd. . . .-switch-loop.jpg   Took down my ceiling fan and found something that I think is odd. . . .-switch-loop-extension-onward.jpg
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
The Following User Says Thank You to Stubbie For This Useful Post:
zappa (01-19-2012)
Old 01-19-2012, 12:23 AM   #3
Doing it myself
Alan's Avatar
That makes sense, since I knew a switch doesn't need a neutral. So they are using one wire to make the switch operate, and in theory the white wire IS actually a black wire, and by your diagram it should be marked as such, similarly to using a white wire on a 240V circuit in a breaker panel.
Thanks. Shoulda been able to figure that one out myself. I'm tired. No more electrical tonight for me.
Journeyman Plumber
Old 01-19-2012, 12:48 AM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Not a problem I am perfectly capable of making a similar oversite talking about plumbing ...
The code did not require the identification of the white wire in the days of cloth wrapped cable.
Stubbie
Old 01-19-2012, 02:15 AM   #5
Rewards Points: 83
Alan, just two things I wanted to add that I've picked up along the way recently.
When you're using a black and white wire both as hots at a switch, it has to be the white that supplies power to the switch and is always hot. It has to be the black that sends power back when the switch is on. It doesn't matter from a will it work standpoint, but they standardized it this way.
Second, NEC 2011 (which is adopted in some areas, but not all) now requires that a real neutral be present at light switches. It's not a safety change - it's so newer "smart" switches that are themselves electronic devices can be used. (Programmable switches, switches that talk to your computer, etc.) Even if NEC 2011 is adopted in your area, this doesn't mean you have to replace your wiring so there's a neutral... Just something to keep in mind if you trigger negating the grandfathering clauses. Also note that if a neutral can very easily be added by putting a new wire into a raceway or open framing cavity to the switch, you can still leave it out.
darlingm is offline   Reply With Quote
The Following User Says Thank You to darlingm For This Useful Post:
zappa (01-19-2012)
