Too Much Wire Load? Is New Proposal Ok? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-10-2009, 12:36 PM   #1
Too much Wire load? Is new Proposal ok?
So I'm wondering if this is ok to do this.
In the living room there an outlet(a) that I'd like to take power from to power 5 recessed lighting and two Outside motion detector lights.
This outlet(a) is connected in series to another outlet(b) which is in turn connected to a wire across the ceiling to a switch where the main power source comes from. Outlet(b), has one constantly on power outlet and the other is switchable.
Never-the-less these two outlets gets it's main power from a 12/3 wire coming from that wall switch which initially powers the switched outlet (b) and then it is wired in series to the second outlet(a).
I'm planning on adding 5 recessed lights and two motion sensor lights and hope to draw power from the location of the wall switch. My goal is to eventually make outlet(b) fulltime on so that I can get rid of the that switch on the wall.
genner is offline   Reply With Quote
Old 03-10-2009, 01:25 PM   #2
joed's Avatar
Rewards Points: 12,014
That will work. Or if one of the receptacles is closer than the switch you could pull power from it.
Old 03-10-2009, 02:32 PM   #3
yeah I think that that's my main concern...
I could pull from the last switch which actually wires back in series to the first switch and then to the switch on the wall. I'm worry that since I'm powering these extra lights and motion detectors, it would be just best to just get the power directly from the wall switch instead of the outlets.
I was thinking that if I were to take the easy route and just wire power directly from the last outlet, with all these lights on at the same time (say 75watts each, it might warm up the romex enough to be a fire hazard, especially if there are devices plugged into those outlets like a TV or stereo system...
Old 03-10-2009, 03:17 PM   #4
How loaded is the circuit? What is the size of the breaker? Make sure your connections are tight, that's where most of the fires start.
12 awg=15 or 20 amp breaker
14 awg=15 amp breaker only.
By the way, to prevent fire spread...fire block your sill plate penetrations...
rgsgww is offline   Reply With Quote
Old 03-10-2009, 03:31 PM   #5
hello rgsgww,
yeah I'm using 12/2 and 12/3 all the way. The whole circuit is on a 15a circuit breaker switch.
Unfortunately this circuit isn't loaded yet. This house has been empty for a while so now it's in a semi-remodeling project. So i'm just planning for the future in case both outlets were to have something heavy on it like a 600watt power supplied computer, a 52" LCD TV and a stereo system and these additional 5 lights and 2 motion sensor lights.
Would heat on that single ROMEX wire even be of concern 1 if I were to wire from the Outlets instead of from the wall switch?
I hope that makes sense...
Old 03-10-2009, 03:36 PM   #6
joed's Avatar
It makes no difference at what point on the circuit you pull the power. It all loads the circuit the same amount.
Old 03-10-2009, 03:36 PM   #7
i don' think it makes a difference, as long as you have the correct fuse size...if you are using #12 and the rest of the existing is 12, you should not have a problem....just make sure if it is a continuous load(which it prob isn't) you don't load teh circuit more than 80%
NolaTigaBait is offline   Reply With Quote
Old 03-10-2009, 03:43 PM   #8
Shouldn't worry about heat. If its all properly sized for breaker and you have good connections, you should be ok.
Old 03-10-2009, 05:14 PM   #9
Electrical Contractor
jbfan's Avatar
Rewards Points: 254
Load it 100% if you want too.
Welcome to the site NoLa
jbfan is online now   Reply With Quote
Old 03-10-2009, 05:47 PM   #10
Roger that!!! Thanks for the reassurance everyone!
Oh one other question...
The sil where the joists rests on the wall side, I have to drill a hole so that I would fish the wire down for the second wall switch. Is there a NEC code on how many ROMEX I can pull through in one Hole? currently my drilled hole is 1/2".
Old 03-10-2009, 08:07 PM   #11
uhhhh, ok......thanks
Old 03-10-2009, 09:20 PM   #12
Electrician
What? Its perfectly fine to load it 100%...
chris75 is offline   Reply With Quote
Old 03-10-2009, 10:32 PM   #13
yea, i know this, man......i was just covering all the bases...ya know that whole continuous load thing...which i stated that it was most likely not seeing that it is residential lighting...but thanks for letting me know
How difficult is 8 AWG wire to work with? PirateKatz Electrical 13 02-16-2009 01:05 PM
New Dryer is 3 wire, receptacle is 4 Wire. thelimit Electrical 22 01-15-2009 10:59 AM
Replacement Light Fixture - Speed Wire Clip? nick4597 Electrical 4 01-03-2009 01:49 PM
Melted Service Entrance Wire in Panel theatretch85 Electrical 13 08-22-2008 11:37 AM
Stove Top wire capt2 Electrical 8 10-05-2007 02:41 PM
