Too Much Voltage - Electrical - DIY Chatroom Home Improvement Forum
Old 11-18-2010, 08:01 PM   #1
Too much voltage
I just recieved a small special welding machine from Euorope today that runs on 220 volts and 50 HZ, we purchased a step up/ step down converter last week for the new machine. Today I pluged everything in and the screen on the welder read to high voltage-260 volts, so the machine would'nt start. It will only run when the voltage is between 200-250 volts. We are at the end of the line so to speak with our power and we have electrical problem which consist of spikes and "dirty power" I've been told. My question is this: can I buy a line conditioner or a voltage regulater to solve this problem and which one would I need to buy? Thanks in advance
saltyguy54 is offline   Reply With Quote
Old 11-18-2010, 08:07 PM   #2
" Euro " electrician
frenchelectrican's Avatar
What kind of welder it is and where you are located.
I am famuair with 50 HZ system due I live in France right now.
Merci.
Marc
Old 11-18-2010, 08:42 PM   #3
Merci.
Marc
it's a ewelcon fusion welder for hdpe pipe, USA
Old 11-18-2010, 08:48 PM   #4
Crap. I know that one very well.,,,
I have use the same welder device as you have.
Ok take the converter off and hook it up direct and I know it can work on 60 HZ system but the timming device will be reading fast and look in back of the nameplate you should see 50/60 HZ if have 60 HZ on the nameplate you are good to go.
Due my unit is stright 50 HZ rated it can not run in 60 HZ supply due the timming device in there.
Check your supply voltage with voltmeter you should be under 250 volts.
If reading too high you may want to give the POCO a head up they will have to check out their system and may have to tap down a little to more useable voltage range.
Otherwise a Buck/Boost transfomer will do this trick.{ not the voltage converter gimzo at all this is a true transfomer }
Merci.
Marc
voltage on earth wire Spikeyboy Electrical 13 10-15-2010 11:03 AM
Voltage in Metal Roof and Gutters TITAN2390 Electrical 4 10-07-2010 07:44 PM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 12:25 PM
Low voltage box question WShawn Electrical 7 08-19-2008 06:22 AM
2 - 900w tansformers on a 15A circuit? tonyBagadonuts Electrical 19 07-20-2008 07:15 PM
