Old 11-05-2009, 12:52 AM   #1
Default Too much NM cable sheath inside j-box?
I'm rewiring my garage and attic. Nothing too complicated... a few junction boxes in the attic (the attic is partially floored and accessible), some lights and outlets. I want to be sure things will pass a home inspection when it's time to sell.
I'm using blue plastic junction boxes and wondering if there is anything wrong with leaving 4 to 6 inches of NM cable folded inside the junction box (or outlet box) with the sheath unstripped.
I've read that one half inch of sheathing should be left inside junction boxes (and outlets), but is it a problem it there is TOO MUCH sheathing?
Would an inspector even check? Or Care?
deko is offline   Reply With Quote
Old 11-05-2009, 01:08 AM   #2
" Euro " electrician
Quarter to half inch sheeting inside the box is fine but NOT 4 to 6 inches it get impossible to get proper hookup with the devices.
I ran into like that many time and most inspectors in both Wisconsin and France are not too kind with it.
If you look at the photo what other members posted on other treads you will get the idea how it done in nice way.
Myself what I do every time I ran into i just strip the rest of it and clean up the box properly.
Merci,
Marc
Old 11-05-2009, 02:45 AM   #3
I'm not too far along on this project, but I will have to fix a couple of j-boxes.
I can hookup the devices fine--that does not appear to be a problem.
I did hear that the extra sheathing inside the box is considered a hazard... because the j-boxes are rated for so many connections and so much heat... and the sheathing is not supposed to in that equation...
Old 11-05-2009, 01:47 PM   #4
After you staple the cables into place and put up the drywall it is very difficult to get the jacket off the cable down to the back of the box when the time comes to use the box.
Strip off the jacket first and then insert the wires into the box. You should have 6 inches of unjacketed wires.
Bait gone and the mouse trap has not snapped? Maybe ants got there first.
Old 11-07-2009, 12:52 AM   #5
Great! Thanks for the feedback, AllanJ.
One other item I'm unsure about is using electrical tape on top of wire nuts.
Is this best practice? The idea is that the tape can prevent the wire nuts from coming loose. Someone told me that commercial work is done this way and should be done with residential as well... ??
Old 11-07-2009, 01:50 AM   #6
Bothing screams handyman/homeowner like too much sheathing.
Just do it right. It's not any more difficult.
220/221 is offline   Reply With Quote
Old 11-07-2009, 09:13 AM   #7
My License Ain't 4 Sale..
Electricians very rarely tape over a wirenut. There is just no reason for it. If it is installed properly so that the wires are twisted under it, it won't back itself off.
Old 11-07-2009, 02:35 PM   #8
This brings up another question: How and when to twist wire?
When you say:
Does this mean I should twist the wires before putting on the wire nut? Or just turn the wire nut hard enough on the untwisted pair so the wires end up twisted? (but then how would I know if they are properly twisted?)
If I should twist first, do I use needle nose pliers to do this? I'm running 12 gauge/20 amp NM cable. Is there some trick or tool to twist 12g wire properly?
Old 11-08-2009, 04:22 AM   #9
Wink maybe some code can help
2005 nec is still the only code used by hud and most electrical inspectors i 40 of 48 states, it will tell you that 4" of free conductor is required in all j boxes. as far a the sheathing in the box 1/4 inch is required by the manufacturer of most boxes but you will need to know the maker and requirements of you specific box and the the rating of the box as far as a fire hazard does not include the small amount of sheathing all you need know is the size of the wire and calculate the cubic inch size if the box you need....a 14 cub in. box can have 3 12/2 cables or 2 12/2
jimkimmi is offline   Reply With Quote
Old 11-08-2009, 10:45 AM   #10
Extreme DIY Homeowner
Scuba_Dave's Avatar
NEC 2008 has been accepted by almost every state by the end of 2009
Only 8 states left for 2010 & 2011
http://www.childoutletsafety.org/fil...doptionMap.pdf
At least 6" of free conductor is required as far as I know
4" will not cut it & may be rejected by an Inspector - mine would reject it
(3) 12-2 = 6 conductors + ground = 7* 2.25, plus 4.5 cu inches for device
That will not fit in a 14 cu inch box
(3) 14-2 = 6 conductors + ground = 7* 2, plus 4 cu inches for device
That will not fit in a 14 cu inch box either
Only CORRECT CODE can help
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/f49/house-renovation-ongoing-37438/
Scuba_Dave is online now   Reply With Quote
Old 11-08-2009, 07:37 PM   #11
You rarely need to twist wires.
If the wires are cut to the same length and the ends are straight, lined up (better than shown here) and held tightly together...
The wires will get twisted together nicely by the wirenut.
Wirenut only
You can pre twist with sidecutters but it is generally a pain and unnecessary. Reworking old splices with bent wires may require pre twisting.
Pre twisted
Old 11-08-2009, 09:05 PM   #12
Thanks for the reply.
So it sounds like twisting is desired, and the preferred way to accomplish this is to let the wire nut do it--which requires the wires to be stripped aligned properly. Is this correct?
Old 11-08-2009, 10:51 PM   #13
Thumbs up
We have a different "rule of thumb". Same size wire gets twisted (not with longnose") and cut to make splice even. Different size wire (12-14 or stranded to solid) is not twisted. to know when the splice is done right, is a "feel" you get after a while! (No matter what) Don't Drink and Drive, ever!!!
spark plug is offline   Reply With Quote
Old 11-08-2009, 11:23 PM   #14
Scuba_Dave's Avatar
How do you feel about soldered connections w/stranded?
I took down some old 2 wire lights in the basement & all connections were soldered
Old 11-10-2009, 02:41 AM   #15
I've heard basic lineman pliers are the best tool for twisting. clipping after twisting to ensure equal lengths sounds like a nice touch.
I'm looking forward to a reply to scuba_dave's question on soldering...
Tags
junction box, nm cable sheath
More On This Topic
Hi, this is Jeff Naylor from Mtroniks in Mesa, Arizona for Expert Village. Your prep work is really dependent on what type of connector you're going to be putting on your speaker cable. Now, as you saw on our last section, we tin the wires if we're going... Read More »
Also, I just want to make it clear when you cue a section and you are using your left hand, it is just like an invitation, you extending your hand, you kind of pointing at them, but if you do it like this, it sometimes makes them a little nervous. So, it... Read More »
I'm Melina and welcome to Expert Village. Today, I am going to show you how to make screen print design on a t-shirt. The first things that you are going to need a regular piece of paper, where you?re going to draw a design. You?re going to need waxy... Read More »
How to Use Wire Strippers
How to Use Wire Strippers by Expert Village
Hi! I'm Drew Finch here for Expert Village and we are talking about standard hand tools and how to use them. Now we are going to use a couple of basic tools to help strip some romex wire if you are doing any wiring. The first thing we have to do is get... Read More »
Sure, you could just get aboard one of those huge megaliners and go through the Panama Canal while sipping your tropical drink up on deck. But if you have more of a sense of adventure, you could sail your own ship through the famous locks yourself. Here... Read More »
Cable question tommy_vercetti Home Theater 15 09-26-2009 11:10 AM
Underground service entrance cable requirements. kgt55 Electrical 9 06-22-2009 08:55 AM
Satellite vs. cable coaxial types? Badfish740 Home Theater 6 02-17-2009 01:00 PM
four wires inside a cable?! joeyboy Electrical 23 11-05-2007 12:31 PM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 04:54 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
