Too Many Wires To Choose From(help) - Electrical - DIY Chatroom Home Improvement Forum
Old 03-23-2008, 02:56 PM   #1
too many wires to choose from(help)
We had track lighting infront of the fireplace. Have a new light and 6 months down the road...dont remember which wires were used before. The condo was built in 2000. The wires we have are 2 white, 3 red, 3 green, 2 blue, 1 blue(there are all capped as mentioned). The light we are hanging has only the 3 wires.
Please help.(we are in Canada if that makes any difference for wiring)
Thankyou
joeandvicki is offline   Reply With Quote
Old 03-23-2008, 04:02 PM   #2
white to white green to green (copper) and I would guess that the black to the singal blue. turn off the power first main service disconect easyer and safer for you.
brad 134 is offline   Reply With Quote
Old 03-23-2008, 04:19 PM   #3
joed's Avatar
Rewards Points: 13,750
That would be my guess as well.
Old 03-23-2008, 08:35 PM   #4
what do we do with all the "left over" wires? Connect all the greens together, blues...etc? Thanks for the help with this. Would you have any idea at all why there are so many wires up there in the one hole? It cant be for a fan as it is so close to the wall.
Old 03-23-2008, 10:06 PM   #5
Rewards Points: 2,350
Do you remember why you disconnected all of the wires, instead of just the ones needed for the fixture?
In any case, it is impossible for anyone to say what wires go to your light without first knowing what each wire is. You need to get a tester and do some tests to figure out what wires are hot, what wires go to the switch, etc. Are you familiar with these tests and do you have a tester?
InPhase277
Old 03-23-2008, 11:06 PM   #6
Prior to the new fixture, there was a track light . All that was removed was that to replace it with a new light. Whilst looking and looking to find the "right" light to replace, we no longer remember/lost the paper where we wrote down what was connected. Now all of those wires were not connected to the track light, that we remember.
We have connected up the light as suggested here and it is working. Thankyou so much for that. Just wondering though, why so many wires???
Do you suppose it is meant to be a three way switch somewhere? We have changed another light and there were just the regular amount of wires up there that easily corresponded with the new fixture. It is a modern concrete condo building . has anyone ever come across this before or even hazzard a guess as to what they could all be used for?
Thanking everyone for their input.
Cheers
Old 03-24-2008, 08:07 AM   #7
joed's Avatar
Leave them alone. They are used to feed other circuits or bring power to the fixture.
Max number of wires you can splice together firemanpato Electrical 12 01-10-2008 06:46 PM
Different color wires on new doorbell transformer.... ConstantChange Electrical 31 11-21-2007 11:08 PM
Two black wires with one white! Please help! ibs325 Electrical 15 11-18-2007 09:38 PM
Running wires mt232 Electrical 4 03-22-2007 08:02 AM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
