Too Many Outlets/fixtures On A Circuit? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-04-2012, 01:56 PM   #1
Rewards Points: 53
Too many outlets/fixtures on a circuit?
I bought a house a few months back -
While failing to fix a wobbling ceiling fan, I noticed that one 15A circuit appears to be controlling a few too many fixtures/outlets than what I would deem normal.
  • 4 duplex outlets
  • 1 duplex GFI outlet
  • 1 quad outlet
  • 8 ceiling fixtures
  • 2 outdoor lights
Too much? It feels like too much.
corsulian is offline   Reply With Quote
Old 10-04-2012, 01:59 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
There is no limit on how much can be on a 15A "lighting circuit". Is the breaker tripping? No? Its fine. Yes? You need to break the circuit up.
The Following 2 Users Say Thank You to k_buz For This Useful Post:
electures (10-04-2012), jrclen (10-18-2012)
Old 10-04-2012, 02:25 PM   #3
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
  • 4 duplex outlets
  • 1 quad outlet
  • 2 outdoor lights
SOunds fine to me. COuld probabley add 10 or 20 more.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 10-04-2012, 03:47 PM   #4
Rewards Points: 53
Still fine if the GFI and two of the fixtures are in a bathroom and two of the ceiling fixtures are fans that are always on?
Old 10-04-2012, 03:58 PM   #5
Pure Genius
Rewards Points: 150
Depends when the house was built but id you havent had a problem yet i wouldnt worry about it.
Dierte is offline   Reply With Quote
Old 10-04-2012, 03:59 PM   #6
k_buz's Avatar
Bathrooms should be on their own 20A circuit, but that code was introduced somewhere around 1990, so your home, depending on age, might be fine code wise. Reality wise, if you have daughters, you will probably experience some lights dimming or the circuit tripping from hair dryers.
Old 10-18-2012, 02:36 PM   #7
Rewards Points: 53
Thanks all-
A friend of the family, a professional electrician, had a look and confirmed everything here: not really a problem right now but we'll eventually want to separate the bathroom outlets to allow for hair dryers and whatnot.
The house was built in 1955 - different areas have seen upgraded/updated electrical at different times ever since - bathroom/kitchen were updated in 2000.
New circuit breaker owen22 Electrical 14 01-12-2010 07:08 PM
open circuit unknown location / voltage leakage fishmanflats Electrical 4 12-23-2009 09:04 PM
Changing a 3 way circuit...using recessed lighting box as a junction box? Oxymoron Electrical 1 12-07-2009 06:46 PM
Circuit out but circuit breaker didn't trip PaulenAndrew Electrical 17 08-16-2008 08:38 AM
