Too Many Lights...help - Electrical - DIY Chatroom Home Improvement Forum
Old 07-29-2012, 09:33 PM   #1
Too many lights...help
I have installed 10 can lights in my basement that I am finishing. My wife wants all of them on one switch. I am afraid that 10 lights will be too much for one 15 amp circuit breaker.
A friend of mine mentioned something about using two breakers and doing a "reverse circuit." (If I remember what he said correctly.)
Would any one here be willing to describe this in more detail or link me to a site?
My wife would also like this on 3-way switches. Possible with this type of circuit?
What is the typical number of lights and outlets that should be on a circuit breaker?
Thanks you for the help.
MrBigTchr is offline   Reply With Quote
Old 07-29-2012, 09:44 PM   #2
Licensed electrician
Rewards Points: 1,288
The number of devices on a circuit depends on the load to be expected on the circuit. For a lighting circuit this is based on the largest bulb the fixture can accept.
I have never heard of a reverse circuit.
Old 07-29-2012, 09:48 PM   #3
Thanks for the response. The lights are rated for 60 Watt max I believe.
I could have the "reverse circuit" term wrong. We were at his wife's grandmother's funeral, so I didn't really ask him to write or draw anything down for me.
Something about 5 lights from one circuit and 5 lights from another circuit and they would meet at the one switch...
If I am remembering that correctly, it just doesn't seem right to me.
Old 07-29-2012, 09:51 PM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Don't listen to your friend...ask us.
To switch two circuits at one location, you'd need a 2 pole switch.
Two switch two circuits at more than one location, you'd need a contactor.
Two switch more than two circuits at one or multiple locations, you'd need a contactor.
However, 10 lights on one circuit is fine even on a 15A circuit. Run one circuit for the lights, and one for the receptacles. Remember you need AFCI protection for the lighting and receptacles. The receptacles need to be tamper resistant as well.
Old 07-29-2012, 10:00 PM   #5
Ten lights at 60 watts rquals a 600 watt load. A 15 amp circuit can support 1800 watts non-continuous or 1440 continuous. Continuous is 3 hours or more by code.
I also think the lights may accept larger than 60 watts, but you can get the idea.
kevinp22 (07-29-2012)
Old 07-30-2012, 02:20 AM   #6
" Euro " electrician
frenchelectrican's Avatar
If you look at the label inside the recessed can and they will list the max wattage they can use I know useally 75 watts or so depending on which trim you plan to use and I/C or pas I/C verison. ( genrally pas I/C are rated higher )
Merci,
Marc
Old 07-30-2012, 06:21 AM   #7
dmxtothemax's Avatar
Rewards Points: 5,108
You worry about nothing !
at 60w each thats only 600w! or 5 amps.
Even at 100w each thats still only 1000w! or 8.3 amps.
All well within the 15 amp breakers ability.
dmxtothemax is offline   Reply With Quote
Old 07-30-2012, 09:01 AM   #8
Rewards Points: 29
You are fine on the circuit and a regular switch, but be careful if she then asks for a dimmer. Most dimmers are only rated to 600w. If the cans are really rated at 60w, then you should still be fine, but any more and you will need a special dimmer.
cube17576 is offline   Reply With Quote
Old 07-30-2012, 10:29 AM   #9
Rewards Points: 660
If using a dimmer, for 10 cans I would get a 1000 watt dimmer, not a 600. I need an ivory 3 way 1000 watt toggle dimmer. Big box stores don't carry quite that specific so i have to order.
B
Beepster is offline   Reply With Quote
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 09:52 AM
Lights still dimming and flickerin Keisha34 Electrical 18 06-09-2012 12:14 AM
Dimming and Flickering lights in home Keisha34 Electrical 34 06-05-2012 03:22 PM
Need info on replacing 8 recessed lights in bathroom OhmZoned Electrical 1 11-07-2011 01:35 PM
Use factory fog light switch for aftermarket lights? downunder Automotive Repairs 6 07-10-2010 12:45 PM
