Too Many Appliances On Tandem Breaker? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-27-2013, 06:21 PM   #1
Rewards Points: 160
Too many appliances on tandem breaker?
Ok so I have a 15amp tandem breaker that is currently powering a dishwasher, fridge and a garbage disposal. On the first pole is the fridge, which is drawing 8.5 amps and on the second pole is the garbage disposal (4.5amps) and the dishwasher (I removed it because it was dead, but possible from being overloaded?)
My question is do tandem breakers have 15 amps running on one pole or is it 15 amps total for both poles?
word2yamutha is offline   Reply With Quote
Old 03-27-2013, 06:24 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,216
Each pole is rated at 15 amps.
Coastal South Carolina
Old 03-27-2013, 06:31 PM   #3
Rewards Points: 160
so 30 amps total? I just want to be clear
Old 03-27-2013, 06:41 PM   #4
A "Handy Husband"
rjniles's Avatar
Not the proper way to express it, it is 15 amps per pole. Or if you want, you can wire 2 15 amp 120 VAC circuits off that tandem breaker.
Old 03-27-2013, 06:43 PM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 488
No, 15 amps each.
They are considered serperate breakers.
Haven't we had this discussion?
Old 03-27-2013, 06:51 PM   #6
Roofmaster
Rewards Points: 2,210
It has always been my impression that a refrigerator, and a dishwasher are supposed to be on their own separate 20 amp circuit. Not sure about the GD.
Old 03-27-2013, 06:58 PM   #7
Rewards Points: 160
Well where I live at there aren't any codes that have to be followed. Yes we have had this discussion before, but I just recently found out that the dishwasher is on the same circuit as the garbage disposal.
I was looking into purchasing a new dishwasher, but I was wondering if it would be too much for the breaker to handle?
Old 03-27-2013, 07:17 PM   #8
A "Handy Husband"
rjniles's Avatar
Most places have codes to be followed. They are often ignored and/or not enforced very well.
Old 03-27-2013, 07:48 PM   #9
Rewards Points: 398
My dishwasher is on its own 15a circuit but my fridge is on the same 20a circuit as 5 other outlets in my kitchen and my house is only 12 years old - so go figure.
Central New Jersey Area
adgjqetuo is offline   Reply With Quote
Old 03-27-2013, 07:56 PM   #10
Master Electrician
Rewards Points: 3,874
That is code compliant provided the other receps are for the countertop and there is another 20 amp circuit for the countertops.
brric is offline   Reply With Quote
Old 03-27-2013, 08:12 PM   #11
Roofmaster
Just look at the amperage rating on the model plate. If you have a septic system, I would deep six that garbage disposal.
Old 03-27-2013, 08:14 PM   #12
Rewards Points: 980
My refrigerator is 1a. Are you sure yours is 8.5a?
You have two breakers; each is good for 15a.
I don't know if it is still allowed to code, but it is common to have the gc and dishwasher on the same circuit.
Toller is offline   Reply With Quote
Old 03-27-2013, 08:27 PM   #13
Master Electrician
On the same 20 amp circuit, not on a 15 amp circuit.
Could you post the brand and model number of that frig?
Old 03-27-2013, 09:14 PM   #14
Rewards Points: 980
One I have now is 1a, one it replaced 5 years ago was 1.5a. Both 25cf. Have to think there is nothing unusual about them.
You might be right about the 20/15a thing; OP should check his cable and see if it is 14 or 12.
Old 03-27-2013, 09:21 PM   #15
Master Electrician
Find that 1amp hard to believe.
The Following User Says Thank You to brric For This Useful Post:
k_buz (03-27-2013)
Outside breaker, inside main breaker panel, so is it a sub? CPF Electrical 29 02-01-2012 10:28 AM
20 amp GFCI breaker pops when pool pump is turned on. jagrunner Electrical 11 03-19-2010 04:31 PM
small voltage on circuit with breaker off jasonmechler Electrical 3 08-24-2009 08:52 AM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
