Too Cold To Get Burned... - Electrical - DIY Chatroom Home Improvement Forum
Old 10-23-2005, 12:06 AM   #1
Too cold to get burned...
I just had two power vents installed by the roofers. One of them nmentioned that they tripped a circuit. I think they have damaged the wiring ehrn they yanked the old power vent out.
Hhow can I test that the power vent works without waiting till summer? The thermostat has a low of 60 and high of 110 degrees.
chicago illinois is offline   Reply With Quote
Old 10-23-2005, 10:25 PM   #2
Remodeler
MinConst's Avatar
I don't kow if this possible in your situation but how about a heat gun?
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 10-24-2005, 01:44 AM   #3
Long-Time DIYer
Mike Swearingen's Avatar
A heat gun or heat lamp near the tstat should turn them on. If it trips the breaker, trace the wiring to find the problem and repair it.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 10-24-2005, 05:48 PM   #4
thank you one and all...i held a hair dryer to the thermostat and het presto it works...thanks.
What is cold room for? KUIPORNG Remodeling 4 04-26-2007 06:06 PM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 09:05 AM
how cold is too cold for vinyl siding? THEBIGPUNN Building & Construction 1 11-22-2005 11:50 PM
Cold Air Return near ceiling or floor? jakobus HVAC 3 07-21-2005 11:54 PM
