Too cold to get burned...
:eek: I just had two power vents installed by the roofers. One of them nmentioned that they tripped a circuit. I think they have damaged the wiring ehrn they yanked the old power vent out.
Hhow can I test that the power vent works without waiting till summer? The thermostat has a low of 60 and high of 110 degrees. |
I don't kow if this possible in your situation but how about a heat gun?
A heat gun or heat lamp near the tstat should turn them on. If it trips the breaker, trace the wiring to find the problem and repair it.
Good luck! Mike |
thank you one and all...i held a hair dryer to the thermostat and het presto it works...thanks.
| All times are GMT -4. The time now is 09:08 AM. |
