Tips For Wiring An Unfinished Basement - Electrical - DIY Chatroom Home Improvement Forum
Old 05-19-2012, 02:21 AM   #1
Rewards Points: 178
Tips for wiring an unfinished basement
I wired the newly constructed apartment on the second floor of my house and now I feel ready to tackle wiring my basement (I'm not turning this into an apartment). The thing is my basement is open & unfinished and will remain open & unfinished for the time being, but the space is used. This means obviously routing the electrical wires through the ceiling joists and, I guess, letting outlet boxes drop from the ceiling where I want power.
I know this isn't normal or to code, but any tips running electrical for this situation? Or is there a better way to provide power outlets for a stud-less, wall-less, open & unfinished basement?
Thanks in advance
P.S. - Finishing the basement will be done in a year or two when the budget allows it. For now, I still want to use the space.
anuvanoob is online now   Reply With Quote
Old 05-19-2012, 06:41 AM   #2
DIY staff
Rewards Points: 7,174
I suggest yo use conduit and steel boxes---simply run around the walls at whatever elevation you like.
Attach the boxes to the wall with short nails shot from a .22 cal stud gun.
Remove from the walls when you do the remodel.
one or two circuits would work
Old 05-19-2012, 07:56 AM   #3
MarginallyQualified
Rewards Points: 2,464
Originally Posted by anuvanoob View Post
This means (making a plan for) routing the electrical wires through the ceiling joists (to known and potential future use points) and, I guess, letting outlet boxes (and wire secured to the exterior wall) from the ceiling where I want power (and/or device boxes secured to the bottom of the joists like lights are).
hope that helps
Old 05-19-2012, 01:20 PM   #4
Rewards Points: 178
Originally Posted by oh'mike View Post
I suggest yo use conduit and steel boxes...
My goodness, I didn't even consider conduits and steel boxes! Very smart! Though I do dread working with conduits... can I minimize the use of them by only using them from the bottom of the ceiling joist to the steel outlet box? If not, is there a different type of conduit that is easier to work with? I only ask these questions because I didn't want to spend more money on electrical for the basement (plus I stupidly bought standard electrical outlets already) and I wanted this to be a quick project since the finished work will be relatively temporary.
That means I'd be attaching the boxes to the cement wall. Will the method you describe work on a cement wall or do I need to use special screws and manually hammer them in?
Originally Posted by TarheelTerp View Post
...from the ceiling where I want power (and/or device boxes secured to the bottom of the joists like lights are).
I'm not sure what you mean here - you mean putting junction boxes in the ceiling joist? If so, for what purpose?
Old 05-19-2012, 01:24 PM   #5
Rewards Points: 6,652
After you get the initial bending down a couple of times, you will be a pro.
Old 05-19-2012, 01:44 PM   #6
liscenced electrician
Rewards Points: 538
You could use pvc. It's easy to bend with heat
jimmy21 is offline   Reply With Quote
Old 05-19-2012, 03:45 PM   #7
MarginallyQualified
You said the basement is open and unfinished (for now at least)... right?
If so then you shouldn't need more than a few lights and a few receptacles down there. This wire (romex) can easily be run through the joists to device boxes. Those boxes (lights or receptacles) can be mounted to the joist.
If you need more than just a few lights or receptacles or if you want to plan your homeruns to meet the future plans... that's good too.
Clearer?
I can't see any reason to use conduit unless you're in Chicago.
The Following User Says Thank You to TarheelTerp For This Useful Post:
Ravenworks (05-20-2012)
Old 05-19-2012, 09:03 PM   #8
DIY staff
Consider this a 'throw away' temporary set up--
When you do finish the basement--no boxes should be hidden behind drywall--so unless you are planning on using a drop ceiling---I'd suggest using the shortest route--
Boxes can be gunned to the concrete wall--or tapcons---buy a conduit bender or borrow one from a friend--conduit is cheap-- oxes are too---just plan on ripping it out when you do your build--Mike--
Old 05-20-2012, 04:52 AM   #9
Rewards Points: 178
Clearer?
Very clear, thanks. I got tripped up on the device boxes thing, never heard them called that.
Why do you say you can't see any reason to use conduit outside of Chicago?
Old 05-20-2012, 06:20 AM   #10
DIY staff
I am from a conduit area---I like the protection that conduit offers on an exposed surface like a basement wall--
How would you prevent damage to the Romex on an open area like this?
I see lots of junk stacked against walls in basements---
Old 05-20-2012, 11:17 PM   #11
Rewards Points: 1,910
I thought just about anywhere (not just Chicago) required conduit in unfinished basements for any wire dropping below the ceiling joists. (unless it is protected within a wall.)
Old 05-21-2012, 12:14 AM   #12
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
You are correct.
Insulate unfinished basement walls? DennyF Insulation 3 02-28-2012 01:36 PM
Should I insulate the ceiling of my unfinished basement? pjm Building & Construction 18 02-17-2011 04:48 PM
Outlet rules for an unfinished room in a finish basement frizbplaya Electrical 1 01-17-2011 01:49 PM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 06:18 PM
Inexpensive way to section off unfinished basement? eastie Building & Construction 0 11-06-2009 05:47 PM
