Tips For Underground IMC Install - Electrical - DIY Chatroom Home Improvement Forum
Old 01-14-2010, 01:42 PM   #1
Tips for underground IMC install
As a follow up to a question I posed last night... Does anyone have any tips or tricks they would like to pass on with running 2" galvanized IMC conduit underground? Due to the soil conditions in Vegas my backyard is pretty much about 12 inches of soil on top of a solid sheet of rock, thus running loose cable or PVC is pretty much a no go without explosives. I've run literally miles of EMT for audio and video lines (Iím a audio systems engineer with a large production show on the strip), but Iíve never had to deal with threaded conduit or the proper sealing for underground purposes. This is going to be permitted and inspected, so I need to cover my bases. They are currently on NEC 2005, but being told that they will be moving to the 2008 code very soon. I'm particular interested if there is pipe dope or wrap I should use in order to prevent water from seeping into the conduit at the conduit connections. I would much rather spend a few more dollars or hours now to prevent major headaches later. Thanks all!
beaker353 is offline   Reply With Quote
Anyone install a tin/copper style ceiling? flashme18 Remodeling 7 07-19-2009 07:56 AM
cutting shingles to install gutters Chicago Bill General DIY Discussions 2 02-27-2009 05:42 AM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
tips for installing Provent insulation baffles? txdiy2607 Roofing/Siding 4 07-03-2008 05:03 PM
