Tips On Running Coax - Electrical - DIY Chatroom Home Improvement Forum
Old 08-29-2008, 10:33 AM   #1
Rewards Points: 1,088
Tips on Running Coax
Any tips on running coax from a living room on the first floor down to the basement? My basement is finished and I tried to poke coax through an AC vent, but am having the toughest time. This vent has flex ducting to the primary duct.
I tried taping the two coaxes together to make it a bit stiffer, tried running fish tape, etc. Not working.
I'm considering tying a string to a plastic bag and using my electric blower and trying to blow it down the vent into the main duct where I can hopefully reach it and then use the string to pull the coax through..
I'd rather not cut through drywall. It looked so simple at first.
handy man88 is offline   Reply With Quote
Old 08-29-2008, 12:03 PM   #2
Res Ipsa Loquitur
Fishing in finished spaces is a pain in most situations. Other than cutting the drywall and using the unforgiving fishtape, you might also want to try fish stix- fiberglass rods used for fishing wires. These are in the electrical section of home centers by Ideal, Greenlee or GB.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 08-29-2008, 01:07 PM   #3
Rewards Points: 82
Run it outside. Seriously.
Sump pump running as much as 20 times per day Shpigford Plumbing 7 06-23-2008 10:33 AM
taco 700 constantly running.... drizzyboy HVAC 3 11-27-2007 08:03 AM
Running coax from attic to room below, via exterior wall? curls00 Electrical 13 08-15-2007 03:18 PM
Running New Coax modena Home Theater 3 07-18-2007 02:18 AM
Coax cable removal or disconnect RobbC2 Electrical 3 04-14-2007 08:21 PM
