Old 10-08-2010, 03:34 PM   #1
Tips on installing pancake box in brick
I want to install 2 porch lights on the outside of my house. I already installed 1 light, but to make the hole in brick for the pancake box wasn't easy. I made some pilots holes around the outline of the box on the brick, and i chiseled the rest until i made the pancake box recessed in the brick. Took me about 2 hours to make that hole.
My question is. Is their a faster way to make that hole in the brick?
humberguy is offline   Reply With Quote
Old 10-08-2010, 03:43 PM   #2
Licensed electrician
I would cut in a regular masonry box. It is almost the size of a brick. Cut the brick to length and then chisel out between the mortar joints. You remove the full depth of the brick. Much easier than chipping out the 1/2" for the pancake.
Old 10-08-2010, 04:23 PM   #3
thanks for your response, i cant believe i didnt think of that before. Now its alot faster now.
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 09:50 AM
Any tips or tricks on installing a line set ? tuckerz HVAC 10 11-04-2009 07:24 AM
New opening in a brick veneer wall - installing new brick ties? GrantJohnson Building & Construction 3 01-28-2009 11:17 AM
Any Tips on Installing Plastic Molding? 1655graff Remodeling 4 11-28-2008 08:36 PM
tips for installing Provent insulation baffles? txdiy2607 Roofing 4 07-03-2008 06:03 PM
