Tips On How I Can Get This Electrical Job Done For A Hot Tub In Backyard. - Electrical - DIY Chatroom Home Improvement Forum
Old 08-12-2010, 04:45 PM   #1
Rewards Points: 33
Tips on how I can get this electrical job done for a hot tub in backyard.
So the hot tub, needs 6-3 wire and 50A GFCI. 220V
The location of the tub is about 30-40 feet from the main panel in the house, right beside the Garage.
From the Main Panel to the garage panel. I have 10-3 wire. 220V It is hooked up at the main like this:
Red to 30Amp breaker,
Black to another 30Amp breaker.
White to neutral bus
Ground to ground bus
Now I am confused as to what my options are, can I connect a Hot tub Panel 50A GFCI to the panel of the garage? So basically I would run 6-3 from the garage panel to the hot tub panel. Can this be done?
I'm assuming you have to bring 6-3 all the way from the Main Panel inside the house to the tub panel, however how is that going to get done when it is all concrete up to the tub?? Can electrical wire run above ground?
the punisher is offline   Reply With Quote
Old 08-12-2010, 05:18 PM   #2
You can't wire a 50a hot tub off a 30a sub panel
And you need an insulated ground to the hot tub
Also a shut off within site of the hot tub
...I forget if there is an exact distance
...plus possibly a bonding grid around the tub depending upon what its sitting on
...with concrete I think you will need the grid
Usually you need conduit to wire up a hot tub
Possibly there is another wiring option
You can't just lay wire along the ground tho
Old 08-12-2010, 05:26 PM   #3
Rewards Points: 33
I see, ok what about replacing the breakers at the Main Panel with 50A, and replacing the sub-panel in the garage with one of 50A?
The 10-3 wire coming from main to garage, has 4 wires, all are insulated and run inside a tube that is running underground to the garage.
Is my only option running a 6-3 from the main to the hot tub panel? If so does this wire need to run under ground?
Old 08-12-2010, 05:48 PM   #4
The 10-3 wire is only rated for 30a
You would need new wire
The garage is detached from the house ?
Is the tub going to be on the far side of the garage...or on the side near the house ?
You need to read thru section 680 of NEC code
Old 08-12-2010, 05:54 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
Punisher, I have been giving advice on these boards for many years. I have to say, there is SO much wrong with your plan, and so much misconception, it scares me. The impression I get is that you really do not have enough experience, and do not know the codes involved with doing a job like this.
It is my professional opinion that you hire someone qualified, licensed and insured.
There is WAY too much at stake with a job like this, such as your family's safety. Don't compromise that for a couple hundred bucks.
Speedy Petey is online now   Reply With Quote
Old 08-12-2010, 06:01 PM   #6
Rewards Points: 33
Yup i did some reading while I awaited your reply and I see that 10/3 is only rated for 30amps, the tub calls for 6/3 50Amp. So it looks like I will need a new wire or find a tub that does not need such high amperage, but that will be hard.
The garage is not attached, the tub would be on the side near the house. I attached a sketch of my layout so you can get a clear idea of the house,tub,garage location.
Since the whole backyard is cemented it would be pretty much impossible to run a new wire underground. Unless the 6/3 wire would fit inside the tube that is going to the garage, pull the 10/3 out and feed the 6/3 through the tube.
Tips on how I can get this electrical job done for a hot tub in backyard.-hottub.jpg
Old 08-12-2010, 06:05 PM   #7
Rewards Points: 33
Don't get me wrong, I am not planning on doing this my self, but before I go out and buy the tub, ( takes 2 months to deliver) I want to make sure that the electrical job for it can be done and the cost of it. If i need to get a 6/3 run from house to tub, that is going to cost quite a bit at $11 a meter, and if so then I need to offset that cost somewhere on the tub upgrades..
Old 08-12-2010, 06:54 PM   #8
You would probably need to feed the garage with more then 50a to satisfy an Inspector on Load Calc
But with concrete between the house & garage that may be your best option
What size is your main panel ?
Old 08-12-2010, 07:05 PM   #9
Rewards Points: 33
Main panel in the house is 200 amp.
I was looking at the tube that goes from the main panel to the garage underground, doesn't look like the 6/3 wire will fit through it, the diameter seems rather small for 6/3 wire.
So I am assuming that the wire will have to run above ground, suspended in the air, as long as it meets code height and cable is weather protected. This adds extra cost cuz now the cable lenght has just become longer having to go up the house, across backyard and down to the hot tub panel.. argh... this is becoming an expensive project.
Can a wire that thick run suspended in the air?
Old 08-12-2010, 07:12 PM   #10
Is the concrete a driveway ?
Or can it be considered one by an Inspector ?
There is a min height over a driveway required
Not sure on what wire you would need
Old 08-12-2010, 07:17 PM   #11
Rewards Points: 33
Nope not a driveway, it is fenced in on both sides.
Anyways I am contacting a couple of electricians for them to come out and give me an idea on price.
At least now I somewhat know what my options are, Thanx for all the help.
Old 08-13-2010, 08:57 AM   #12
Rewards Points: 756
There are hot tubs (spas) that run on a 20A 120V cord/plug connection.
busman is offline   Reply With Quote
Old 08-13-2010, 09:17 AM   #13
Rewards Points: 33
I have yet to find one. I have checked Artic Spas , beachcomber, Maybe have to look harder
Old 08-13-2010, 09:55 AM   #14
They are usually the smaller 2-3 person hot tubs
But I do have an old one that was taken apart that was maybe 6x6' , 4-6 people could fit in it & it plugged into a 20a circuit - T slot plug
Old 08-13-2010, 11:25 AM   #15
Originally Posted by the punisher View Post
...Since the whole backyard is cemented it would be pretty much impossible to run a new wire underground...
A concrete saw will make it very easy.
unlvrebel is offline   Reply With Quote
Changing from Electrical Cook Top to Electrical Range EkS Electrical 24 06-22-2010 10:43 AM
How to install new electrical box without attic access gilmores33 Electrical 10 02-14-2010 07:46 PM
Electrical Codes and Tips ponch37300 Electrical 51 08-28-2009 10:14 PM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 11:12 AM
Outdoor backyard electrical for lighting, water fountain, shed nabz Electrical 1 05-25-2009 09:58 PM
