Timers For Chargers? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-30-2013, 09:39 AM   #1
Bill Kearney
Rewards Points: 1,174
timers for chargers?
I'm wondering if anyone's dealt with this before, or what products might work for it.
I've got a kid with a couple of different batteries for outdoor toys. Power Wheels jeep and the like. I'd like to have some sort of easy to use timer setup so my wife (or possibly my child) could turn the circuit on and have it only run for a preset amount of time. This so the batteries don't sit on the charger for an excessively long period of time. I've already upgraded to more intelligent chargers than the factory supplied ones, so that's not an issue
This setup would be inside the basement, so outdoor requirements wouldn't be an issue. I'd kind of like to be able to 'flip a switch' and just have it run for probably around 6-9 hours max and then shut off until manually activated again.
And, no, I don't want to get into using the old-school Intermatic dial-type timers. I specifically do NOT want to set up the timer to always run at specific times. Something like how bathrooms at campgrounds or marinas have a knob you turn to activate the lights for a set period of time. I just need a lot longer and interval than the typical 30 minute duration those possess.
Any products come to mind for this?
wkearney99 is offline   Reply With Quote
Old 08-30-2013, 09:46 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 554
Something like this?
http://1000bulbs.com/product/3298/EL...icegrabber.com
Old 08-30-2013, 09:47 AM   #3
Bill Kearney
Perhaps something like this:
http://www.amazon.com/Woods-59014-De.../dp/B002C54GH4
Old 08-30-2013, 09:49 AM   #4
Bill Kearney
Originally Posted by jbfan View Post
Ah! That's what I'm after. I just didn't seem to be able to use the right search terms to narrow down to it.
There's a 12-hour model as well:
http://www.amazon.com/Intermatic-FD1.../dp/B0047CPAJ8
Old 08-30-2013, 09:50 AM   #5
jbfan's Avatar
Rewards Points: 554
Either the one I listed, or the one you listed will work.
Old 08-30-2013, 09:53 AM   #6
Bill Kearney
I'm also considering something like that for a cell phone and gadget charging station. I'm planning putting a built-in cabinet in the mudroom. I'd like to use the top of it for charging phones and the like. And put all the transformers in an out-of-view location below (with sufficient ventilation of course).
It'd be nice to have a timer switch in view that allowed turning the whole set off when not needed, as a way to cut down on wasted power consumption. But it'd have to be something usable by the non-technical folks in the house (aka, the wife). That Woods unit might be just the ticket. The intermatic one would be great for the car battery chargers.
Old 08-30-2013, 10:59 AM   #7
Rewards Points: 204
What about those cheap ones that plug into a receptacle? No wiring required.
Just plug your stuff in.
You can set it for on/off operation.
They were all over the TV commercials for years.
Old 08-30-2013, 03:25 PM   #8
Bill Kearney
Originally Posted by J. V. View Post
What about those cheap ones that plug into a receptacle? No wiring required. Just plug your stuff in. You can set it for on/off operation.
Don't want any cords visible, nor have to root through any.
For the phones the charger cords will all drop into a slot in the cabinet top, with all the transformers in a space below. I'd prefer to have a wall or cabinet-mounted switch for this (thus the Woods item).
Same thing for the car chargers, best to have the control for them out from the tangle of cords for the chargers and leads to the batteries.
Old 08-30-2013, 03:40 PM   #9
This makes me kinda think of another question with regards to chargers.
Do you all just leave your portable drill chargers plugged in all the time with a battery in them or do you unplug when the job is done and hope that next time you need to use your drill the battery hasn't lost all juice?
dabeast is offline   Reply With Quote
Old 08-31-2013, 01:43 PM   #10
Rewards Points: 1,704
Pictured are watt readings of current draw of a Hitachi portable drill / flash light combo charger. The discharged battery reads 54 watts when charging begins and 03 watts when fully charged less than an hour later. I wouldn't own a charger that doesn't self regulate. I have more funner things to do that set the duck quacker on my iphone to remind me to go turn a charger off.
So my answer is yes, I have one of the two batteries on the charger 24/7.
I have an elderly sister so tight she climbs over the gate to save hinge wear.
All timers quit at once, HELP! kheren Electrical 2 06-29-2011 03:08 PM
Hose Bib Sprinkler Timers WirelessG Landscaping & Lawn Care 0 06-02-2011 07:55 PM
Air exchanger. Replace room switches with timers? murray59 HVAC 17 05-12-2010 08:16 PM
two timers on one switch keano016 Electrical 3 04-06-2010 08:15 AM
Delay on Break timers rjbaiad HVAC 6 09-24-2008 05:17 AM
