Timer Switch Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 06-12-2011, 08:57 PM   #1
timer switch wiring
i am attempting to wire a new timer switch onto an exsisting circut. the wiring comming from the wall box is the old cloth covered non color coded wires. the new switch has three wires, red, black and white.there is no indication that the box itself is grounded nor is there a visible ground wire comming from the box. if i use white as nuetral and black as hot can the red wire on the wall switch be cut, stripped and capped?
mlang43 is offline   Reply With Quote
Old 06-12-2011, 09:03 PM   #2
Electrical Contractor
kbsparky's Avatar
Nope. Won't work at all if you cap the red wire. The red wire is for the switched load.
How many wires are in the switch box? If there are only 2 present, this timer switch will not work.
-KB
Old 06-13-2011, 03:09 PM   #3
there are only two wires comming from the box. it looks like whoever installed the first timer marked one wire as blue and one as black. looks like ill need another timer...thank you so much for your help
Wiring Diagram Symbols for Timer Switch caruso81 Electrical 5 04-10-2011 07:10 PM
Help installing wall switch light timer Aube TI071 Rachey Electrical 10 12-24-2010 12:02 PM
Wiring Bathroom fan to dual switch joerob25 Electrical 3 12-15-2010 11:11 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
Wiring a Ceiling Fan to a Switch that also Controlls Hot Switch timsarah Electrical 6 03-30-2010 09:14 AM
