Timer Switch Has 4 Wires. Only 3 Wires On Switch By Itself. Now What. - Electrical - DIY Chatroom Home Improvement Forum
Old 11-14-2011, 07:28 PM   #1
Rewards Points: 588
Timer switch has 4 wires. Only 3 wires on switch by itself. Now what.
Trying to install a timer with 4 wires on a wire with only 3 wires. It is a single outlet that wires into the line voltage outdoor lighting.
I pulled out the box and there is no other wires or anything hiding behind it.
How do I wire this?
Timer switch has 4 wires.  Only 3 wires on switch by itself.  Now what.-photo-1-6.jpg   Timer switch has 4 wires.  Only 3 wires on switch by itself.  Now what.-photo-2-6.jpg
noone is offline   Reply With Quote
Old 11-14-2011, 07:55 PM   #2
Sparky
Rewards Points: 510
you need a neutral.
you cannot install that switch without replacing the wire in the switch box with 14/3 (black red white bare)
Techy is offline   Reply With Quote
Old 11-14-2011, 07:58 PM   #3
Electrician
SD515's Avatar
Rewards Points: 504
or 12/3. The NM coming out of the wall looks like it might be 12ga.
Kyle
The Following User Says Thank You to SD515 For This Useful Post:
Speedy Petey (11-15-2011)
Old 11-14-2011, 08:12 PM   #4
Rewards Points: 588
So I don't have a neutral here? What's the white wire on the romex?
Can I just buy a switch with 3 wires?
Old 11-14-2011, 08:21 PM   #5
Electrician
SD515's Avatar
Rewards Points: 504
No, there isn’t a neutral there, it’s a switch leg. If it was done correctly, the white should bring power into the box, and the black return it to the load. You can check if your local store has a timer that doesn’t require a neutral, but it’ll probably just be a manual ‘ticker’ type.
Kyle
Old 11-14-2011, 08:47 PM   #6
Rewards Points: 588
Originally Posted by SD515 View Post
No, there isnít a neutral there, itís a switch leg. If it was done correctly, the white should bring power into the box, and the black return it to the load. You can check if your local store has a timer that doesnít require a neutral, but itíll probably just be a manual Ďtickerí type.
What are my realistic options here?
I thought this would be a simple wam bam thank you ma'am install. Especially after I just replaced all the line level outdoor lighting fixtures and boxes which basically took me all day.
How do I run 14/3?
Old 11-14-2011, 08:57 PM   #7
Rewards Points: 588
How do I run 14/3?
Or do I just make this a receptacle outlet and plug in a stinking round timer to it? Yuck.
Old 11-14-2011, 09:05 PM   #8
Electrician
SD515's Avatar
Rewards Points: 504
Check how the current cable is run and where. It might be pretty easy to replace. From the pictureÖI see a metal cut-in box and no cable clamp on it. That tells me itís been fished in, which means it should be easy to use it as a Ďpull stringí and pull a 3 wire cable in. Attach/tape the new cable onto the old cable and use it to pull the new one in. Use 14/3 if itís a 15A circuit, 12/3 if itís a 20A.
If you did convert it to a receptacle, then you wouldn't have a way to switch the lights.
Kyle
Old 11-14-2011, 09:39 PM   #9
Rewards Points: 588
removed..
Old 11-14-2011, 09:47 PM   #10
Rewards Points: 588
Ok, did some recon.
Here's what I got.
It appears that their are two 14/2 wires running from the breaker box to this junction box. Then attached to this is a run to the outdoor lights outside and a run to the switch.
What can I do here? Not sure what to replace here, as I'm hoping you don't mean I have to replace romex all the way back to the breaker box. There are red wires in the switch next door and those wires are accessible up in the attic.
I guess it's on a 5amp breaker?? It's the off switch in the pic.
Timer switch has 4 wires.  Only 3 wires on switch by itself.  Now what.-photo-2.jpg   Timer switch has 4 wires.  Only 3 wires on switch by itself.  Now what.-photo-3.jpg   Timer switch has 4 wires.  Only 3 wires on switch by itself.  Now what.-photo.jpg
Old 11-15-2011, 06:07 AM   #11
Sparky
Rewards Points: 510
you need to replace the wire from the switch box to that junction box
Old 11-15-2011, 07:07 AM   #12
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Originally Posted by Techy View Post
you need to replace the wire from the switch box to that junction box.......
...with a 12/3, since that is #12 wire on a 20A breaker.
Make the black the feed down to the switch, the red the switched wire, and the white the neutral.
The Following User Says Thank You to Speedy Petey For This Useful Post:
Techy (11-15-2011)
Both wires in switch are black Manshri Electrical 3 02-06-2011 08:47 AM
Timer Switch Hookup Yankee1423 Electrical 6 02-05-2011 10:02 PM
Single Pole Light Switch with 4 Wires dmwiecz Electrical 6 11-22-2010 07:41 PM
Trying to install Leviton In-Wall LCD timer switch Proulx06 Electrical 36 11-05-2009 11:15 PM
Timer switch...any ideas how it works? mcvane Electrical 5 09-28-2008 07:32 AM
