Timer Switch Ground Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 02-18-2012, 09:00 PM   #1
Rewards Points: 518
Timer switch ground wire
I'm in Canada and the Canadian Electrical Code does not require light switches to be grounded. With that in mind, electricians typically will snip the ground wires after they wrap around the metal box screws leaving it difficult to extend if needed later.
I'm installing a handful of Leviton bathroom timers that have a green stranded ground wire running off of them. Is there any real need to connect the ground wire? I don't want to attempt to extend the line ground wire unless the switch circuitry actually requires a ground.
n0c7 is offline   Reply With Quote
Old 02-18-2012, 09:04 PM   #2
joed's Avatar
Rewards Points: 13,322
Just put it under the screw. There are usually 2 screws in the box allowing for four connections. The screws also have a raise tab beside them to hold the wire. You do not need to wrap it. You can just put it under one side of the screw. The raise tab will hold it in.
Old 02-18-2012, 09:07 PM   #3
Rewards Points: 518
There are 4 cables entering the box, 4 ground screws(double gang box) and each screw is being used and has been clipped too short to be usable.
Old 02-18-2012, 09:21 PM   #4
" Euro " electrician
frenchelectrican's Avatar
Joed.,
I know this will get a little off topic a little but it will be the same as we are on this subject but let me expand this question little more if you can bear with me.
If The OP did used all 4 grounding screws and can your CEC allow to make a pigtail and land one of the grounding screw ?
I am famuair with Canada verison of junction box so I kinda got some idea but want to run it by ya first due you have the code with ya so you will know this one.
Merci,
Marc
Old 02-18-2012, 10:33 PM   #5
joed's Avatar
Cutting ground short after the screw is proper in Canada. Pigtails should be fine if you need an additional connection for ground. If the ground was needed for a receptacle for example it would normally be put under the screw and left long for the receptacle.
The Following User Says Thank You to joed For This Useful Post:
frenchelectrican (02-19-2012)
Old 02-18-2012, 10:35 PM   #6
Rewards Points: 518
Can I just skip the ground on the new digital timer?
Old 02-19-2012, 08:03 AM   #7
Rewards Points: 826
In the time you've researched this it could be done. It's easy enough to do. Go ahead and tie in the ground of the switch and remove the doubt in your mind if it will work properly. Its too small an issue to leave unresolved.
curiousB is offline   Reply With Quote
Connecting new dishwasher and garbage disposal -- no ground wire in the conduits. arca Electrical 17 03-28-2011 02:06 AM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
Will reverse polarity trip breaker?? Duane 70 Electrical 60 12-05-2008 10:18 PM
old wire, backfed switch question Jack A. Trades Electrical 6 07-03-2008 11:05 AM
