Timer Switch At End Of Run - Electrical - DIY Chatroom Home Improvement Forum
Old 05-15-2011, 03:35 PM   #1
Timer switch at end of run
A friend of mine asked me to look at a timer switch he attempted to install. The box looks like it is at the end of the run, coming from an outdoor light. there are no wires leaving the box. The problem is that the wire coming in is 4 wire, red, black, white and ground. 3-way wiring?? But my friend swears the outdoor light is only controlled by one switch. 120v indicated with Multi meter across red and black and red and white and 0v across the black and white.
1. General question. How is a timer switch wired at the end of the run? Timer wiring diagram in middle of the run is supplied with the timer. easy enough. How is it done at end of run?
2. Could this 4 wire only be using 3 of the wires?
stumped!!
tmaher is offline   Reply With Quote
Old 05-15-2011, 04:04 PM   #2
Scared Electrician
Saturday Cowboy's Avatar
actually thats 3wire, don't count the ground, it is always there so professionals, and suppliers do not mention it.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 05-15-2011, 04:40 PM   #3
joed's Avatar
Rewards Points: 12,922
You will need to open the fixture and see how it is connected.
You should be able to connect it at the fixture so that white and black connect to the power in neutral and hot. The red connects to the fixture black. Then at the timer the black and white are connected to power in a neutral(many timers need a neutral) and the red is the switched power back to the fixture.
Old 05-16-2011, 06:06 AM   #4
You are correct. I knew that too!!
Bathroom exhaust fan/light timer switch zephed666 Electrical 7 04-29-2011 11:25 AM
Wiring GE Smart Digital Timer to 3 way switch. Wing Electrical 16 08-26-2010 06:22 PM
timer lite switch F SMITH Electrical 0 08-10-2010 03:44 PM
fan timer on a switch loop someguy86 Electrical 3 08-02-2010 08:05 PM
Timer switch...any ideas how it works? mcvane Electrical 5 09-28-2008 06:32 AM
