Old 02-22-2008, 04:14 PM   #1
Exclamation
Timer Switch
I am trying to replace a timer switch and my building is two wires (red & white) and the new switch uses a neutral, line, line1 and load. I can't seem to figure out the right combo.
scarv71 is offline   Reply With Quote
Old 02-22-2008, 04:23 PM   #2
My License Ain't 4 Sale..
Timer Switch
Are you saying that you only have two wires at the timer location? The timer requires a neutral and constant hot in order to power the timer motor. A separate wire carries switched power to the light. You need at least three wires, plus a ground at the switch.
InPhase277
Old 02-22-2008, 04:32 PM   #3
Timer Switch
I have two red and one white.
Old 02-22-2008, 07:02 PM   #4
Timer Switch
One red is going to be the feed to the circuit, the other red will go to the light, and the white is neutral. It sounds like you have a terminal for the neutral, and a terminal for the clock motor. The other two are for the load. Check this diagram.
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 10:34 PM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 06:06 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 03:53 PM
