Old 11-14-2011, 08:18 PM   #1
Timer with override switch
I am wiring up my to-be-finished basement and had the idea of having a receptacle wired on a timer but with a switch override. My thought was that a timer would be a good move given my kids propensity to leave things on, but have an "override switch" in case an adult wants the equipment on for a longer duration. Is this possible? any idea how to wire that up?
jimmyhopps is offline   Reply With Quote
Old 11-14-2011, 08:33 PM   #2
Electrician
SD515's Avatar
I think an occupancy sensor would be a better choice. What are you wanting to control with this?
Kyle
Old 11-14-2011, 08:50 PM   #3
You may be right about the occupancy sensor. thanks.
i was planning on having some of the lights run off it.
Old 11-15-2011, 07:59 PM   #4
actually an occupancy sensor will not work for this purpose, as the objective of the switch is to override the timer either on or off.
Old 11-15-2011, 08:58 PM   #5
Electrician
SD515's Avatar
Occ sensors that take the place of a wall switch have manual on/off switches in them. Here’s a link to Leviton occ sensors page, to look at for some ideas/info.
http://www.leviton.com/OA_HTML/ibeCC...minisite=10026
Kyle
timer switch wiring mlang43 Electrical 2 06-13-2011 03:09 PM
Is it possible to override IR sensor with single switch? torizus Electrical 5 03-13-2011 04:05 PM
Wiring GE Smart Digital Timer to 3 way switch. Wing Electrical 16 08-26-2010 07:22 PM
fan timer on a switch loop someguy86 Electrical 3 08-02-2010 09:05 PM
Timer switch...any ideas how it works? mcvane Electrical 5 09-28-2008 07:32 AM
